阅读:3481回复:0
网页FLASH动画禁止右键菜单的方法
更多 发布于:2011-12-15 23:47
 在做一个实验时遇到一个禁止flash的右键功能的问题。在网上找了很多方法,要不就完全不行,要不就浏览器不兼容。google了一下国外的情况,终于找到了一个不错的方法。该方法用了javascript和as的结合,完美解决了问题。
  以下是javascript部分代码:
  var Rightclick = {
  * Constructor
  init: function () {
  this.FlashObjectID = “customRightClick”;
  this.FlashContainerID = “flashcontent”;
  this.Cache = this.FlashObjectID;
  if(window.addEventListener){
  window.addEventListener(“mousedown”, this.onGeckoMouse(), true);
  } else {
  document.getElementById(this.FlashContainerID).onmouseup = function() { document.getElementById(RightClick.FlashContainerID).releaseCapture(); }
  document.oncontextmenu = function(){ if(window.event.srcElement.id == RightClick.FlashObjectID) { return false; } else { RightClick.Cache = “nan”; }}
  document.getElementById(this.FlashContainerID).onmousedown = RightClick.onIEMouse;
  * GECKO / webKIT event overkill
  * @param {Object} eventObject
  killEvents: function(eventObject) {
  if(eventObject) {
  if (eventObject.stopPropagation) eventObject.stopPropagation();
  if (eventObject.preventDefault) eventObject.preventDefault();
  if (eventObject.preventCapture) eventObject.preventCapture();
  if (eventObject.preventBubble) eventObject.preventBubble();
  * GECKO / WEBKIT call right click
  onGeckoMouse: function(ev) {
  return function(ev) {
  if (ev.button != 0) {
  RightClick.killEvents(ev);
  if(ev.target.id == RightClick.FlashObjectID ;; RightClick.Cache == RightClick.FlashObjectID) {
  RightClick.call();
  RightClick.Cache = ev.target.id;
  * IE call right click
  onIEMouse: function() {
  if (event.button> 1) {
  if(window.event.srcElement.id == RightClick.FlashObjectID ;; RightClick.Cache == RightClick.FlashObjectID) {
  RightClick.call();
  document.getElementById(RightClick.FlashContainerID).setCapture();
  if(window.event.srcElement.id)
  RightClick.Cache = window.event.srcElement.id;
  * Main call to Flash External interface
  call: function() {
  document.getElementById(this.FlashObjectID).rightClick();
  var RightClick = {
   * Constructor
   init: function () {
   this.FlashObjectID = "customRightClick";
   this.FlashContainerID = "flashcontent";
   window.addEventListener("mousedown", this.onGeckoMouse(), true);
   } else {
   document.oncontextmenu = function(){ if(window.event.srcElement.id == RightClick.FlashObjectID) { return false; } else { RightClick.Cache = "nan"; }}
   * GECKO / WEBKIT event overkill
   if(eventObject) {
   RightClick.call();
   RightClick.call();
   * Main call to Flash External Interface
   call: function() {
  }以下是as部分代码:
  package {
  import flash.display.*;
  import flash.external.ExternalInterface;
  public classclass RightClick extends Sprite
  public function RightClick()
  stage.scaleMode = StageScaleMode.NO_SCALE;
  stage.align = StageAlign.TOP_LEFT;
  var methodName:String = “rightClick”;
  var method:Function = onRightClick;
  ExternalInterface.addCallback(methodName, method);
  private function onRightClick():void {
  var mx:int = stage.mouseX;
  var my:int = stage.mouseY;
  if(my> 0 ;; my 0 ;; mx
