阅读:4536回复:0
[二级考试]计算机二级VB常用算法:进制转化进10进制数
更多 发布于:2012-08-22 13:54
下面程序是把给定的16进制正整数转换为10进制数。 以下是片段:
  Option Explicit
  Private Sub Form_Click()
  Dim St As Integer, Dem As Long
  St=InputBox("输入一个十六进制数")
  Dem=Convert(St)
  Print St; ">="; Dem
  End Sub
  Private Function Convert(S As String)As Long
  Dim N As Integer, I As Integer,Substring As String*1
  Dim P As long, K As Long,Asc1 As Integer
  N= (1)
  P=16^N
  For I=1 To N
  P=P/16
  Substring= (2)
  Select Case Substring
  Case "0" To "9"
  K=K+P*Val(Substring)
  Case (3)
  Asc1=Asc(Substring)-Asc("A")+10
  (4)
  End Select
  Next I
