阅读:4352回复:0
网站如何防SQL注入
更多 发布于:2012-08-24 21:51
网站如何防SQL注入
步骤/方法
第一种:
squery=lcase(Request.ServerVariables("QUERY_STRING"))
sURL=lcase(Request.ServerVariables("HTTP_HOST"))
SQL_injdata =":|;|>|<|--|sp_|xp_||dir|cmd|^|(|)|+|$|'|copy|format|and|exec|insert|select|delete|update|count|*|%|chr|mid|master|truncate|char|declare"
SQL_inj = split(SQL_Injdata,"|")
For SQL_Data=0 To Ubound(SQL_inj)
if instr(squery;sURL,Sql_Inj(Sql_DATA))>0 Then
Response.Write "SQL通用防注入系统"
Response.end
end if
next
第二种:
If Request.QueryString<>"" Then
For Each SQL_Get In Request.QueryString
if instr(Request.QueryString(SQL_Get),Sql_Inj(Sql_DATA))>0 Then
Response.end
end if
next
Next
End If
If Request.Form<>"" Then
For Each Sql_Post In Request.Form
if instr(Request.Form(Sql_Post),Sql_Inj(Sql_DATA))>0 Then
Response.end
end if
next
next
end if
第三种
'--------定义部份------------------
Dim Str_Post,Str_Get,Str_In,Str_Inf,Str_Xh,Str_db,Str_dbstr
'自定义需要过滤的字串,用 "■"分离
Str_In = "'■;■and■exec■insert■select■delete■update■count■*■%■chr■mid■master■truncate■char■declare"
Str_Inf = split(Str_In,"■")
'--------POST部份------------------
For Each Str_Post In Request.Form
For Str_Xh=0 To Ubound(Str_Inf)
If Instr(LCase(Request.Form(Str_Post)),Str_Inf(Str_Xh))<>0 Then
'--------写入数据库----------头-----
Str_dbstr="DBQ="+server.mappath("SqlIn.mdb")+";DefaultDir=;DRIVER={Microsoft Access Driver (*.mdb)};"
Set Str_db=Server.CreateObject("ADODB.CONNECTION")
Str_db.open Str_dbstr
Str_db.Execute("insert into SqlIn(Sqlin_IP,SqlIn_web,SqlIn_FS,SqlIn_CS,SqlIn_SJ) values('";Request.ServerVariables("REMOTE_ADDR");"','";Request.ServerVariables("URL");"','POST','";Str_Post;"','";replace(Request.Form(Str_Post),"'","''");"')")
Str_db.close
Set Str_db = Nothing
'--------写入数据库----------尾-----
Response.Write "<Script Language=javaScript>alert('请不要在参数中包含非法字符尝试注入!');</Script>"
Response.Write "非法操作!系统做了如下记录:<br>"
Response.Write "操作IP:";Request.ServerVariables("REMOTE_ADDR");"<br>"
Response.Write "操作时间:";Now;"<br>"
Response.Write "操作页面:";Request.ServerVariables("URL");"<br>"
Response.Write "提交方式:POST<br>"
Response.Write "提交参数:";Str_Post;"<br>"
Response.Write "提交数据:";Request.Form(Str_Post)
Response.End
End If
Next
Next
End If
'--------GET部份-------------------
For Each Str_Get In Request.QueryString
If Instr(LCase(Request.QueryString(Str_Get)),Str_Inf(Str_Xh))<>0 Then
Str_db.Execute("insert into SqlIn(Sqlin_IP,SqlIn_Web,SqlIn_FS,SqlIn_CS,SqlIn_SJ) values('";Request.ServerVariables("REMOTE_ADDR");"','";Request.ServerVariables("URL");"','GET','";Str_Get;"','";replace(Request.QueryString(Str_Get),"'","''");"')")
Str_db.close
Response.Write "<Script Language=javaScript>alert('请不要在参数中包含非法字符尝试注入!);</Script>"
Response.Write "提交方式:GET<br>"
Response.Write "提交参数:";Str_Get;"<br>"
Response.Write "提交数据:";Request.QueryString(Str_Get)
Response.End
End If
Next
Next
End If
注意事项
第3中方法需要你自己建个数据库
