阅读:2860回复:0
[mysql]MySQL分表优化
更多 发布于:2012-09-01 02:11
我们的项目中有好多不等于的情况。今天写这篇文章简单的分析一下怎么个优化法。
  这里的分表逻辑是根据t_group表的user_name组的个数来分的。
  因为这种情况单独user_name字段上的索引就属于烂索引。起不了啥名明显的效果。
  1、试验PROCEDURE.
DELIMITER $$
Drop PROCEDURE `t_girl`.`sp_split_table`$$
Create PROCEDURE `t_girl`.`sp_split_table`()
BEGIN
 declare done int default 0;
 declare v_user_name varchar(20) default '';
 declare v_table_name varchar(64) default '';
 -- Get all users' name.
 declare cur1 cursor for select user_name from t_group group by user_name;
 -- Deal with error or warnings.
 declare continue handler for 1329 set done = 1;
 -- Open cursor.
 open cur1;
 while done <> 1
 do
  fetch cur1 into v_user_name;
  if not done then
   -- Get table name.
   set v_table_name = concat('t_group_',v_user_name);
   -- Create new extra table.
   set @stmt = concat('create table ',v_table_name,' like t_group');
   prepare s1 from @stmt;
   execute s1;
   drop prepare s1;
   -- Load data into it.
   set @stmt = concat('insert into ',v_table_name,' select * from t_group where user_name = ''',v_user_name,'''');
   execute s1;
   drop prepare s1;
  end if;
 end while;
 -- Close cursor.
 close cur1;
 -- Free variable from memory.
 set @stmt = NULL;
END$$
DELIMITER ;
  2、试验表。
  我们用一个有一千万条记录的表来做测试。
mysql> select count(*) from t_group;
| count(*) |
| 10388608 |
1 row in set (0.00 sec)
  表结构。
mysql> desc t_group;
| Field   | Type      | Null | Key | Default     | Extra     |
| id     | int(10) unsigned | NO | PRI | NULL       | auto_increment |
| money   | decimal(10,2)  | NO |  |         |        |
| user_name | varchar(20)   | NO | MUL |         |        |
| create_time | timestamp    | NO |  | CURRENT_TIMESTAMP |        |
4 rows in set (0.00 sec)
  索引情况。
mysql> show index from t_group;
|Table | Non_unique | Key_name    | Seq_in_index | Column_name |Collation | Cardinality | Sub_part | Packed | Null | Index_type |Comment |
|t_group |     0 | PRIMARY     |      1 | id     |A    |  10388608 |  NULL | NULL |   | BTREE  |    |
| t_group |     1 | idx_user_name  |     1 | user_name | A    |     8 |  NULL | NULL |   |BTREE   |    |
| t_group |     1 | idx_combination1|      1 | user_name | A    |     8 |  NULL |NULL |   | BTREE   |    |
| t_group |     1 |idx_combination1 |      2 | money   | A    |    3776|  NULL | NULL |   | BTREE   |    |
  PS:
  idx_combination1 这个索引是必须的,因为要对user_name来GROUP BY。此时属于松散索引扫描!当然完了后你可以干掉她。
  idx_user_name 这个索引是为了加快单独执行constant这种类型的查询。
  我们要根据用户名来分表
mysql> select user_name from t_group where 1 group by user_name;
| user_name |
| david  |
| leo   |
| livia  |
| lucy   |
| sarah  |
| simon  |
| sony   |
| sunny  |
8 rows in set (0.00 sec)
  所以结果表应该是这样的。
mysql> show tables like 't_group_%';
| Tables_in_t_girl (t_group_%) |
| t_group_david        |
| t_group_leo         |
| t_group_livia        |
| t_group_lucy        |
| t_group_sarah        |
| t_group_simon        |
| t_group_sony        |
| t_group_sunny        |
  3、对比结果。
mysql> select count(*) from t_group where user_name = 'david';
| count(*) |
| 1298576 |
1 row in set (1.71 sec)
  执行了将近2秒。
mysql> select count(*) from t_group_david;
| count(*) |
| 1298576 |
  几乎是瞬间的。
mysql> select count(*) from t_group where user_name <> 'david';
| count(*) |
| 9090032 |
1 row in set (9.26 sec)
执行了将近10秒,可以想象,这个是实际的项目中是不能忍受的。
mysql> select (select count(*) from t_group) - (select count(*) from t_group_david) as total;
| total |
| 9090032 |
  几乎是瞬间的。
  我们来看看聚集函数。
  对于原表的操作。
mysql> select min(money),max(money) from t_group where user_name = 'david';
| min(money) | max(money) |
|   -6.41 |  500.59 |
最小,最大值都是FULL INDEX SCAN。所以是瞬间的。
mysql> select sum(money),avg(money) from t_group where user_name = 'david';
| sum(money) | avg(money) |
| 319992383.84 | 246.417910 |
1 row in set (2.15 sec)
其他聚集函数的结果就不是FULL INDEX SCAN了。耗时2.15秒。
  对于小表的操作。
mysql> select min(money),max(money) from t_group_david;
|   -6.41 |  500.59 |
1 row in set (1.50 sec)
  最大最小值完全是FULL TABLE SCAN,耗时1.50秒,不划算。以此看来。
mysql> select sum(money),avg(money) from t_group_david;
1 row in set (1.68 sec)
  取得这两个结果也是花了快2秒,快了一点。
  我们来看看这个小表的结构。
mysql> desc t_group_david;
  明显的user_name属性是多余的。那么就干掉它。
mysql> alter table t_group_david drop user_name;
Query OK, 1298576 rows affected (7.58 sec)
Records: 1298576 Duplicates: 0 Warnings: 0
  现在来重新对小表运行查询
|   -6.41 |  500.59 |
  此时是瞬间的。
1 row in set (0.94 sec)
  这次算是控制在一秒以内了。
  mysql> Aborted
  小总结一下:分出的小表的属性尽量越少越好。大胆的去干吧
