阅读:2228回复:0
[mysql]Fdeora16安装mysql
更多 发布于:2012-09-01 02:15
yum install mysql
yum install mysql-server
yum install mysql-devel
chgrp -R mysql /var/lib/mysql
chmod -R 770 /var/lib/mysql
service mysqld start
修改root的密码
mysqladmin -u root password 'newpassword' 更改密码
mysql -u root -p   登录数据库
mysql> DROP DATABASE test;   删除test数据库
mysql> DELETE FROM mysql.user WHERE user = ''; 删除匿名帐户
mysql> FLUSH PRIVILEGES;   重载权限
添加mysql用户:GRANT ALL PRIVILEGES ON my_db.* TO 'user'@'localhost' IDENTIFIED BY 'password';
# sudo service mysqld restart  重启服务
# sudo service mysqld stop  关闭服务 www.atcpu.com
/etc/rc.d/init.d/mysqld status   查看mysql状态
# sudo chkconfig --del mysqld  删除服务清单中mysql服务
chkconfig --list    察看mysql是否在自动启动列表中
#sudo /etc/init.d/mysqld start   启动mysql服务
#sudo /etc/init.d/mysqld stop   关闭mysql服务
#sudo /etc/init.d/mysqld restart   重启mysql服务
/usr/bin/mysqladmin -u root -p'password' shutdown关闭mysql服务
作者 Sharpleo
