µÆ»ð»¥Áª
¹ÜÀíÔ±
¹ÜÀíÔ±
  • ×¢²áÈÕÆÚ2011-07-27
  • ·¢ÌûÊý41778
  • »ð±Ò41290ö
  • ·ÛË¿1086
  • ¹Ø×¢100
  • ÖÕÉí³É¾Í½±
  • ×ɳ·¢
  • ÖÒʵ»áÔ±
  • ¹àË®Ìì²Å½±
  • Ìùͼ´óʦ½±
  • Ô­´´ÏÈ·æ½±
  • ÌØÊâ¹±Ï×½±
  • Ðû´«´óʹ½±
  • ÓÅÐã°ßÖñ½±
  • ÉçÇøÃ÷ÐÇ
ÔĶÁ£º3058»Ø¸´£º0
[mysql]MySqlÓ¦ÓõĻù±¾²Ù×÷Óï¾ä
Â¥Ö÷#
¸ü¶à ·¢²¼ÓÚ£º2012-09-01 02:18
1.µ¼³öÕû¸öÊý¾Ý¿â
mysqldump -u Óû§Ãû -p --default-character-set=latin1 Êý¾Ý¿âÃû > µ¼³öµÄÎļþÃû(Êý¾Ý¿âĬÈϱàÂëÊÇlatin1)
mysqldump -u wcnc -p smgp_apps_wcnc > wcnc.sql
2.µ¼³öÒ»¸ö±í
mysqldump -u Óû§Ãû -p Êý¾Ý¿âÃû ±íÃû> µ¼³öµÄÎļþÃû
mysqldump -u wcnc -p smgp_apps_wcnc users> wcnc_users.sql
3.µ¼³öÒ»¸öÊý¾Ý¿â½á¹¹
mysqldump -u wcnc -p -d ¨cadd-drop-table smgp_apps_wcnc >d:wcnc_db.sql
-d ûÓÐÊý¾Ý ¨Cadd-drop-table ÔÚÿ¸öcreateÓï¾ä֮ǰÔö¼ÓÒ»¸ödrop table
4.µ¼ÈëÊý¾Ý¿â
A:³£ÓÃsource ÃüÁî
½øÈëmysqlÊý¾Ý¿â¿ØÖÆÌ¨£¬
Èçmysql -u root -p
mysql>use Êý¾Ý¿â
È»ºóʹÓÃsourceÃüÁºóÃæ²ÎÊýΪ½Å±¾Îļþ(ÈçÕâÀïÓõ½µÄ.sql)
mysql>source wcnc_db.sql  www.atcpu.com
B:ʹÓÃmysqldumpÃüÁî
mysqldump -u username -p dbname < filename.sql
C:ʹÓÃmysqlÃüÁî
mysql -u username -p -D dbname < filename.sql
Ò»¡¢Æô¶¯ÓëÍ˳ö
1¡¢½øÈëMySQL£ºÆô¶¯MySQL Command Line Client£¨MySQLµÄDOS½çÃæ£©£¬Ö±½ÓÊäÈ밲װʱµÄÃÜÂë¼´¿É¡£´ËʱµÄÌáʾ·ûÊÇ£ºmysql>
2¡¢Í˳öMySQL£ºquit»òexit
¶þ¡¢¿â²Ù×÷
1¡¢¡¢´´½¨Êý¾Ý¿â
ÃüÁcreate database <Êý¾Ý¿âÃû>
ÀýÈ磺½¨Á¢Ò»¸öÃûΪxhkdbµÄÊý¾Ý¿â
mysql> create database xhkdb;
2¡¢ÏÔʾËùÓеÄÊý¾Ý¿â
ÃüÁshow databases £¨×¢Ò⣺×îºóÓиös£©
mysql> show databases;
3¡¢É¾³ýÊý¾Ý¿â
ÃüÁdrop database <Êý¾Ý¿âÃû>
ÀýÈ磺ɾ³ýÃûΪ xhkdbµÄÊý¾Ý¿â
mysql> drop database xhkdb;
4¡¢Á¬½ÓÊý¾Ý¿â
ÃüÁ use <Êý¾Ý¿âÃû>
ÀýÈ磺Èç¹ûxhkdbÊý¾Ý¿â´æÔÚ£¬³¢ÊÔ´æÈ¡Ëü£º
mysql> use xhkdb;
ÆÁÄ»Ìáʾ£ºDatabase changed
5¡¢²é¿´µ±Ç°Ê¹ÓõÄÊý¾Ý¿â
mysql> select database();
6¡¢µ±Ç°Êý¾Ý¿â°üº¬µÄ±íÐÅÏ¢£º
mysql> show tables; £¨×¢Ò⣺×îºóÓиös£©
Èý¡¢±í²Ù×÷£¬²Ù×÷֮ǰӦÁ¬½Óij¸öÊý¾Ý¿â
1¡¢½¨±í  www.atcpu.com
ÃüÁcreate table <±íÃû> ( <×Ö¶ÎÃû1> <ÀàÐÍ1> [,..<×Ö¶ÎÃûn> <ÀàÐÍn>]);
mysql> create table MyClass(
> id int(4) not null primary key auto_increment,
> name char(20) not null,
> sex int(4) not null default '0',
> degree double(16,2));
2¡¢»ñÈ¡±í½á¹¹
ÃüÁ desc ±íÃû£¬»òÕßshow columns from ±íÃû
mysql>DESCRIBE MyClass
mysql> desc MyClass;
mysql> show columns from MyClass;
3¡¢É¾³ý±í
ÃüÁdrop table <±íÃû>
ÀýÈ磺ɾ³ý±íÃûΪ MyClass µÄ±í
mysql> drop table MyClass;
4¡¢²åÈëÊý¾Ý
ÃüÁinsert into <±íÃû> [( <×Ö¶ÎÃû1>[,..<×Ö¶ÎÃûn > ])] values ( Öµ1 )[, ( Öµn )]
ÀýÈ磬Íù±í MyClassÖвåÈë¶þÌõ¼Ç¼, Õâ¶þÌõ¼Ç¼±íʾ£º±àºÅΪ1µÄÃûΪTomµÄ³É¼¨Îª96.45, ±àºÅΪ2 µÄÃûΪJoan µÄ³É¼¨Îª82.99£¬±àºÅΪ3 µÄÃûΪWang µÄ³É¼¨Îª96.5.
mysql> insert into MyClass values(1,'Tom',96.45),(2,'Joan',82.99), (2,'Wang', 96.59);
5¡¢²éѯ±íÖеÄÊý¾Ý
1)¡¢²éѯËùÓÐÐÐ
ÃüÁ select <×Ö¶Î1£¬×Ö¶Î2£¬...> from < ±íÃû > where < ±í´ïʽ >
ÀýÈ磺²é¿´±í MyClass ÖÐËùÓÐÊý¾Ý
mysql> select * from MyClass;
2£©¡¢²éѯǰ¼¸ÐÐÊý¾Ý
ÀýÈ磺²é¿´±í MyClass ÖÐǰ2ÐÐÊý¾Ý
mysql> select * from emp order by empno limit 0,2;
»òÕߣº
mysql> select * from emp limit 0,2;
6¡¢É¾³ý±íÖÐÊý¾Ý
ÃüÁdelete from ±íÃû where ±í´ïʽ
ÀýÈ磺ɾ³ý±í MyClassÖбàºÅΪ1 µÄ¼Ç¼
mysql> delete from MyClass where id=1;
7¡¢Ð޸ıíÖÐÊý¾Ý
update ±íÃû set ×Ö¶Î=ÐÂÖµ,¡­ where Ìõ¼þ
mysql> update MyClass set name='Mary' where id=1;
7¡¢ÔÚ±íÖÐÔö¼Ó×ֶΣº
ÃüÁalter table ±íÃû add×Ö¶Î ÀàÐÍ ÆäËû;
ÀýÈ磺ÔÚ±íMyClassÖÐÌí¼ÓÁËÒ»¸ö×Ö¶Îpasstest£¬ÀàÐÍΪint(4)£¬Ä¬ÈÏֵΪ0
mysql> alter table MyClass add passtest int(4) default '0'
8¡¢¸ü¸Ä±íÃû£º
ÃüÁrename table Ô­±íÃû to бíÃû;
ÀýÈ磺ÔÚ±íMyClassÃû×Ö¸ü¸ÄΪYouClass
mysql> rename table MyClass to YouClass;
9¡¢¸üÐÂ×Ö¶ÎÄÚÈÝ
update ±íÃû set ×Ö¶ÎÃû = ÐÂÄÚÈÝ
update ±íÃû set ×Ö¶ÎÃû = replace(×Ö¶ÎÃû,'¾ÉÄÚÈÝ','ÐÂÄÚÈÝ');
ÎÄÕÂÇ°Ãæ¼ÓÈë4¸ö¿Õ¸ñ
update article set content=concat('¡¡¡¡',content);
×Ö¶ÎÀàÐÍ
1£®INT[(M)] ÐÍ£º Õý³£´óСÕûÊýÀàÐÍ
2£®DOUBLE[(M,D)] [ZEROFILL] ÐÍ£º Õý³£´óС(Ë«¾«ÃÜ)¸¡µãÊý×ÖÀàÐÍ
3£®DATE ÈÕÆÚÀàÐÍ£ºÖ§³ÖµÄ·¶Î§ÊÇ1000-01-01µ½9999-12-31¡£MySQLÒÔYYYY-MM-DD¸ñʽÀ´ÏÔʾDATEÖµ£¬µ«ÊÇÔÊÐíÄãʹÓÃ×Ö·û´®»òÊý×Ö°ÑÖµ¸³¸øDATEÁÐ
4£®CHAR(M) ÐÍ£º¶¨³¤×Ö·û´®ÀàÐÍ£¬µ±´æ´¢Ê±£¬×ÜÊÇÊÇÓÿոñÌîÂúÓұߵ½Ö¸¶¨µÄ³¤¶È
5£®BLOB TEXTÀàÐÍ£¬×î´ó³¤¶ÈΪ65535(2^16-1)¸ö×Ö·û¡£
6£®VARCHARÐÍ£º±ä³¤×Ö·û´®ÀàÐÍ  www.atcpu.com
5.µ¼ÈëÊý¾Ý¿â±í
¡¡¡¡ £¨1£©´´½¨.sqlÎļþ
¡¡¡¡ £¨2£©ÏȲúÉúÒ»¸ö¿âÈçauction.c:mysqlbin>mysqladmin -u root -p creat auction£¬»áÌáʾÊäÈëÃÜÂ룬Ȼºó³É¹¦´´½¨¡£
¡¡¡¡ £¨2£©µ¼Èëauction.sqlÎļþ
¡¡¡¡ c:mysqlbin>mysql -u root -p auction < auction.sql¡£
¡¡¡¡ ͨ¹ýÒÔÉϲÙ×÷£¬¾Í¿ÉÒÔ´´½¨ÁËÒ»¸öÊý¾Ý¿âauctionÒÔ¼°ÆäÖеÄÒ»¸ö±íauction¡£
6£®ÐÞ¸ÄÊý¾Ý¿â
¡¡¡¡ £¨1£©ÔÚmysqlµÄ±íÖÐÔö¼Ó×ֶΣº
¡¡¡¡ alter table dbname add column userid int(11) not null primary key auto_increment;
¡¡¡¡ ÕâÑù£¬¾ÍÔÚ±ídbnameÖÐÌí¼ÓÁËÒ»¸ö×Ö¶Îuserid£¬ÀàÐÍΪint(11)¡£
7£®mysqlÊý¾Ý¿âµÄÊÚȨ
¡¡¡¡ mysql>grant select,insert,delete,create,drop
¡¡¡¡ on *.* (»òtest.*/user.*/..)
¡¡¡¡ to Óû§Ãû@localhost
¡¡¡¡ identified by 'ÃÜÂë'£»
¡¡¡¡ È磺н¨Ò»¸öÓû§ÕʺÅÒÔ±ã¿ÉÒÔ·ÃÎÊÊý¾Ý¿â£¬ÐèÒª½øÐÐÈçϲÙ×÷£º
¡¡¡¡ mysql> grant usage
¡¡¡¡ -> ON test.*
¡¡¡¡ -> TO testuser@localhost;
¡¡¡¡ Query OK, 0 rows affected (0.15 sec)
¡¡¡¡ ´Ëºó¾Í´´½¨ÁËÒ»¸öÐÂÓû§½Ð£ºtestuser£¬Õâ¸öÓû§Ö»ÄÜ´ÓlocalhostÁ¬½Óµ½Êý¾Ý¿â²¢¿ÉÒÔÁ¬½Óµ½test Êý¾Ý¿â¡£ÏÂÒ»²½£¬ÎÒÃDZØÐëÖ¸¶¨testuserÕâ¸öÓû§¿ÉÒÔÖ´ÐÐÄÄЩ²Ù×÷£º
¡¡¡¡ mysql> GRANT select, insert, delete,update
¡¡¡¡ -> ON test.*
¡¡¡¡ Query OK, 0 rows affected (0.00 sec)
¡¡¡¡ ´Ë²Ù×÷ʹtestuserÄܹ»ÔÚÿһ¸ötestÊý¾Ý¿âÖеıíÖ´ÐÐSELECT£¬INSERTºÍDELETEÒÔ¼°UPDATE²éѯ²Ù×÷¡£ÏÖÔÚÎÒÃǽáÊø²Ù×÷²¢Í˳öMySQL¿Í»§³ÌÐò£º
¡¡¡¡ mysql> exit
¡¡¡¡ Bye9!
8:ÏÔʾ±íµÄ½á¹¹£º
mysql> DESCRIBE MYTABLE;
9:Íù±íÖмÓÈë¼Ç¼
mysql> insert into MYTABLE values ("hyq","M");
10:ÓÃÎı¾·½Ê½½«Êý¾Ý×°ÈëÊý¾Ý¿â±íÖУ¨ÀýÈçD:/mysql.txt£©
ÄÚÈÝ£º3 rose ÉîÛÚ¶þÖÐ 1976-10-10
¡¡¡¡   4 mike ÉîÛÚÒ»ÖÐ 1975-12-23
mysql> LOAD DATA LOCAL INFILE "D:/mysql.txt" INTO TABLE MYTABLE;
11:µ¼Èë.sqlÎļþÃüÁÀýÈçD:/mysql.sql£©
mysql>use database;
mysql>source d:/mysql.sql;
ÔÚwindowsÖÐMySqlÒÔ·þÎñÐÎʽ´æÔÚ£¬ÔÚʹÓÃǰӦȷ±£´Ë·þÎñÒѾ­Æô¶¯£¬Î´Æô¶¯¿ÉÓÃnet start mysqlÃüÁîÆô¶¯¡£¶øLinuxÖÐÆô¶¯Ê±¿ÉÓá°/etc/rc.d/init.d/mysqld start"ÃüÁעÒâÆô¶¯ÕßÓ¦¾ßÓйÜÀíԱȨÏÞ¡£
¸Õ°²×°ºÃµÄMySql°üº¬Ò»¸öº¬¿ÕÃÜÂëµÄrootÕÊ»§ºÍÒ»¸öÄäÃûÕÊ»§£¬ÕâÊǺܴóµÄ°²È«Òþ»¼£¬¶ÔÓÚÒ»Ð©ÖØÒªµÄÓ¦ÓÃÎÒÃÇÓ¦½«°²È«ÐÔ¾¡¿ÉÄÜÌá¸ß£¬ÔÚÕâÀïÓ¦°ÑÄäÃûÕÊ»§É¾³ý¡¢ rootÕÊ»§ÉèÖÃÃÜÂ룬¿ÉÓÃÈçÏÂÃüÁî½øÐУº
use mysql;
delete from User where User="";
ÐÞ¸ÄÃÜÂ룺update User set Password=PASSword('newpassword') where User='root';
Èç¹ûÒª¶ÔÓû§ËùÓõĵǼÖն˽øÐÐÏÞÖÆ£¬¿ÉÒÔ¸üÐÂUser±íÖÐÏàÓ¦Óû§µÄHost×ֶΣ¬ÔÚ½øÐÐÁËÒÔÉϸü¸ÄºóÓ¦ÖØÐÂÆô¶¯Êý¾Ý¿â·þÎñ£¬´ËʱµÇ¼ʱ¿ÉÓÃÈçÏÂÀàËÆÃüÁ
mysql -uroot -p;  www.atcpu.com
mysql -uroot -pnewpassword;
mysql mydb -uroot -p;
mysql mydb -uroot -pnewpassword;
ÉÏÃæÃüÁî²ÎÊýÊdz£ÓòÎÊýµÄÒ»²¿·Ö£¬ÏêϸÇé¿ö¿É²Î¿¼Îĵµ¡£´Ë´¦µÄmydbÊÇÒªµÇ¼µÄÊý¾Ý¿âµÄÃû³Æ¡£
ÔÚ½øÐпª·¢ºÍʵ¼ÊÓ¦ÓÃÖУ¬Óû§²»Ó¦¸ÃÖ»ÓÃrootÓû§½øÐÐÁ¬½ÓÊý¾Ý¿â£¬ËäȻʹÓÃrootÓû§½øÐвâÊÔʱºÜ·½±ã£¬µ«»á¸øÏµÍ³´øÀ´ÖØ´ó°²È«Òþ»¼£¬Ò²²»ÀûÓÚ¹ÜÀí¼¼ÊõµÄÌá¸ß¡£ÎÒÃǸøÒ»¸öÓ¦ÓÃÖÐʹÓõÄÓû§¸³Óè×îÇ¡µ±µÄÊý¾Ý¿âȨÏÞ¡£ÈçÒ»¸öÖ»½øÐÐÊý¾Ý²åÈëµÄÓû§²»Ó¦¸³ÓèÆäɾ³ýÊý¾ÝµÄȨÏÞ¡£MySqlµÄÓû§¹ÜÀíÊÇͨ¹ý User±íÀ´ÊµÏֵģ¬Ìí¼ÓÐÂÓû§³£Óõķ½·¨ÓÐÁ½¸ö£¬Ò»ÊÇÔÚUser±í²åÈëÏàÓ¦µÄÊý¾ÝÐУ¬Í¬Ê±ÉèÖÃÏàÓ¦µÄȨÏÞ£»¶þÊÇͨ¹ýGRANTÃüÁî´´½¨¾ßÓÐijÖÖȨÏÞµÄÓû§¡£ÆäÖÐGRANTµÄ³£ÓÃÓ÷¨ÈçÏ£º
grant all on mydb.* to NewUserName@HostName identified by "password" ;
grant usage on *.* to NewUserName@HostName identified by "password";
grant select,insert,update on mydb.* to NewUserName@HostName identified by "password";
grant update,delete on mydb.TestTable to NewUserName@HostName identified by "password";
ÈôÒª¸ø´ËÓû§¸³ÓèËûÔÚÏàÓ¦¶ÔÏóÉϵÄȨÏ޵ĹÜÀíÄÜÁ¦£¬¿ÉÔÚGRANTºóÃæÌí¼ÓWITH GRANT OPTIONÑ¡Ïî¡£¶ø¶ÔÓÚÓòåÈëUser±íÌí¼ÓµÄÓû§£¬Password×Ö¶ÎÓ¦ÓÃPASSword º¯Êý½øÐиüмÓÃÜ£¬ÒÔ·À²»¹ìÖ®ÈËÇÔ¿´ÃÜÂë¡£¶ÔÓÚÄÇЩÒѾ­²»ÓõÄÓû§Ó¦¸øÓèÇå³ý£¬È¨ÏÞ¹ý½çµÄÓû§Ó¦¼°Ê±»ØÊÕȨÏÞ£¬»ØÊÕȨÏÞ¿ÉÒÔͨ¹ý¸üÐÂUser±íÏàÓ¦×ֶΣ¬Ò²¿ÉÒÔʹÓÃREVOKE²Ù×÷¡£
È«¾Ö¹ÜÀíȨÏÞ£º
FILE: ÔÚMySQL·þÎñÆ÷É϶ÁдÎļþ¡£
PROCESS: ÏÔʾ»òɱËÀÊôÓÚÆäËüÓû§µÄ·þÎñÏ̡߳£
RELOAD: ÖØÔØ·ÃÎÊ¿ØÖÆ±í£¬Ë¢ÐÂÈÕÖ¾µÈ¡£
SHUTDOWN: ¹Ø±ÕMySQL·þÎñ¡£
Êý¾Ý¿â/Êý¾Ý±í/Êý¾ÝÁÐȨÏÞ£º
Alter: ÐÞ¸ÄÒÑ´æÔÚµÄÊý¾Ý±í(ÀýÈçÔö¼Ó/ɾ³ýÁÐ)ºÍË÷Òý¡£
Create: ½¨Á¢ÐµÄÊý¾Ý¿â»òÊý¾Ý±í¡£
Delete: ɾ³ý±íµÄ¼Ç¼¡£
Drop: ɾ³ýÊý¾Ý±í»òÊý¾Ý¿â¡£
INDEX: ½¨Á¢»òɾ³ýË÷Òý¡£
Insert: Ôö¼Ó±íµÄ¼Ç¼¡£
Select: ÏÔʾ/ËÑË÷±íµÄ¼Ç¼¡£
Update: Ð޸ıíÖÐÒÑ´æÔڵļǼ¡£
ÌØ±ðµÄȨÏÞ£º
ALL: ÔÊÐí×öÈκÎÊÂ(ºÍrootÒ»Ñù)¡£
USAGE: Ö»ÔÊÐíµÇ¼--ÆäËüʲôҲ²»ÔÊÐí×ö¡£
MYSQL³£ÓÃÃüÁ ¡¡
Ò»¡¢Á¬½ÓMYSQL¡¡
¡¡¡¡¸ñʽ£º mysql -hÖ÷»úµØÖ· -uÓû§Ãû £­pÓû§ÃÜÂë ¡¡¡¡
¡¡¡¡1¡¢Àý1£ºÁ¬½Óµ½±¾»úÉϵÄMYSQL
¡¡¡¡Ê×ÏÈÔÚ´ò¿ªDOS´°¿Ú£¬È»ºó½øÈëĿ¼ mysqlbin£¬ÔÙ¼üÈëÃüÁîmysql -uroot -p£¬»Ø³µºóÌáʾÄãÊäÃÜÂ룬Èç¹û¸Õ°²×°ºÃMYSQL£¬³¬¼¶Óû§rootÊÇûÓÐÃÜÂëµÄ£¬¹ÊÖ±½Ó»Ø³µ¼´¿É½øÈëµ½MYSQLÖÐÁË£¬MYSQLµÄÌáʾ·ûÊÇ£ºmysql> ¡¡¡¡
¡¡¡¡2¡¢Àý2£ºÁ¬½Óµ½Ô¶³ÌÖ÷»úÉϵÄMYSQL
¡¡¡¡¼ÙÉèÔ¶³ÌÖ÷»úµÄIPΪ£º110.110.110.110£¬Óû§ÃûΪroot,ÃÜÂëΪabcd123¡£Ôò¼üÈëÒÔÏÂÃüÁ ¡¡¡¡¡¡
¡¡¡¡mysql -h110.110.110.110 -uroot -pabcd123 ¡¡¡¡
¡¡¡¡£¨×¢:uÓëroot¿ÉÒÔ²»Óüӿոñ£¬ÆäËüÒ²Ò»Ñù£© ¡¡¡¡
¡¡¡¡3¡¢Í˳öMYSQLÃüÁ exit £¨»Ø³µ£©
¡¡¡¡¶þ¡¢ÐÞ¸ÄÃÜÂë¡¡  www.atcpu.com  ¡¡
¡¡¡¡¸ñʽ£ºmysqladmin -uÓû§Ãû -p¾ÉÃÜÂë password ÐÂÃÜÂë ¡¡
¡¡¡¡1¡¢Àý1£º¸øroot¼Ó¸öÃÜÂëab12¡£Ê×ÏÈÔÚDOSϽøÈëĿ¼mysqlbin£¬È»ºó¼üÈëÒÔÏÂÃüÁî ¡¡¡¡
¡¡¡¡mysqladmin -uroot -password ab12 ¡¡¡¡
¡¡¡¡×¢£ºÒòΪ¿ªÊ¼Ê±rootûÓÐÃÜÂ룬ËùÒÔ-p¾ÉÃÜÂëÒ»Ïî¾Í¿ÉÒÔÊ¡ÂÔÁË¡£ ¡¡¡¡
¡¡¡¡2¡¢Àý2£ºÔÙ½«rootµÄÃÜÂë¸ÄΪdjg345
¡¡¡¡mysqladmin -uroot -pab12 password djg345
Èý¡¢½«Îı¾Êý¾Ýתµ½Êý¾Ý¿âÖÐ
¡¡¡¡1¡¢Îı¾Êý¾ÝÓ¦·ûºÏµÄ¸ñʽ£º×Ö¶ÎÊý¾ÝÖ®¼äÓÃtab¼ü¸ô¿ª£¬nullÖµÓÃ\nÀ´´úÌæ.
¡¡¡¡Àý£º
¡¡¡¡3 rose ÉîÛÚ¶þÖÐ 1976-10-10
¡¡¡¡4 mike ÉîÛÚÒ»ÖÐ 1975-12-23
¡¡¡¡2¡¢Êý¾Ý´«ÈëÃüÁî load data local infile "ÎļþÃû" into table ±íÃû;
¡¡¡¡×¢Ò⣺Äã×îºÃ½«Îļþ¸´ÖƵ½\mysql\binĿ¼Ï£¬²¢ÇÒÒªÏÈÓÃuseÃüÁî´ò±íËùÔڵĿ⠡£
ËÄ¡¢±¸·ÝÊý¾Ý¿â£º£¨ÃüÁîÔÚDOSµÄ\mysql\binĿ¼ÏÂÖ´ÐУ©
¡¡¡¡mysqldump --opt school>school.bbb
¡¡¡¡×¢ÊÍ:½«Êý¾Ý¿âschool±¸·Ýµ½school.bbbÎļþ£¬school.bbbÊÇÒ»¸öÎı¾Îļþ£¬ÎļþÃûÈÎÈ¡£¬´ò¿ª¿´¿´Äã»áÓÐз¢ÏÖ¡£
1¡¢ ALL¡¢DISTINCT¡¢DISTINCTROW¡¢TOPν´Ê
(1) ALL ·µ»ØÂú×ãSQLÓï¾äÌõ¼þµÄËùÓмǼ¡£Èç¹ûûÓÐÖ¸Ã÷Õâ¸öν´Ê£¬Ä¬ÈÏΪALL¡£
Àý£ºSELECT ALL FirstName,LastName FROM Employees
(2) DISTINCT Èç¹ûÓжà¸ö¼Ç¼µÄÑ¡Ôñ×ֶεÄÊý¾ÝÏàͬ£¬Ö»·µ»ØÒ»¸ö¡£
(3) DISTINCTROW Èç¹ûÓÐÖØ¸´µÄ¼Ç¼£¬Ö»·µ»ØÒ»¸ö
(4) TOPÏÔʾ²éѯͷβÈô¸É¼Ç¼¡£Ò²¿É·µ»Ø¼Ç¼µÄ°Ù·Ö±È£¬ÕâÊÇÒªÓà TOP N PERCENT×Ӿ䣨ÆäÖÐN ±íʾ°Ù·Ö±È£©
Àý£º·µ»Ø5%¶¨»õ¶î×î´óµÄ¶¨µ¥
SELECT TOP 5 PERCENT* FROM [ Order Details] ORDER BY UnitPrice*Quantity*(1-Discount) DESC
2¡¢ Óà AS ×Ó¾äΪ×Ö¶ÎÈ¡±ðÃû
Èç¹ûÏëΪ·µ»ØµÄÁÐȡһ¸öеıêÌ⣬»òÕߣ¬¾­¹ý¶Ô×ֶεļÆËã»ò×ܽáÖ®ºó£¬²úÉúÁËÒ»¸öеÄÖµ£¬Ï£Íû°ÑËü·Åµ½Ò»¸öеÄÁÐÀïÏÔʾ£¬ÔòÓÃAS±£Áô¡£
Àý£º·µ»ØFirstName×Ö¶ÎÈ¡±ðÃûΪNickName
SELECT FirstName AS NickName ,LastName ,City FROM Employees
Àý£º·µ»ØÐµÄÒ»ÁÐÏÔʾ¿â´æ¼ÛÖµ
SELECT ProductName ,UnitPrice ,UnitsInStock ,UnitPrice*UnitsInStock AS valueInStock FROM Products
¶þ .WHERE ×Ó¾äÖ¸¶¨²éѯÌõ¼þ
1¡¢ ±È½ÏÔËËã·û
±È½ÏÔËËã·û º¬Òå
= µÈÓÚ
> ´óÓÚ
< СÓÚ
>= ´óÓÚµÈÓÚ
<= СÓÚµÈÓÚ
<> ²»µÈÓÚ
!> ²»´óÓÚ
!< ²»Ð¡ÓÚ
Àý£º·µ»Ø96Äê1ÔµĶ¨µ¥
SELECT OrderID, CustomerID, OrderDate FROM Orders WHERE OrderDate>#1/1/96# AND OrderDate<#1/30/96#
×¢Ò⣺
Mcirosoft JET SQL ÖУ¬ÈÕÆÚÓá®#¡¯¶¨½ç¡£ÈÕÆÚÒ²¿ÉÒÔÓÃDatevalue()º¯ÊýÀ´´úÌæ¡£ÔڱȽÏ×Ö·ûÐ͵ÄÊý¾Ýʱ£¬Òª¼ÓÉϵ¥ÒýºÅ¡¯¡¯£¬Î²¿Õ¸ñÔڱȽÏÖб»ºöÂÔ¡£
Àý£º
WHERE OrderDate>#96-1-1#
Ò²¿ÉÒÔ±íʾΪ£º
WHERE OrderDate>Datevalue(¡®1/1/96¡¯)
  www.atcpu.com
2¡¢ ·¶Î§£¨BETWEEN ºÍ NOT BETWEEN£©
BETWEEN ¡­AND¡­ÔËËã·ûÖ¸¶¨ÁËÒªËÑË÷µÄÒ»¸ö±ÕÇø¼ä¡£
Àý£º·µ»Ø96Äê1Ôµ½96Äê2ÔµĶ¨µ¥¡£
WHERE OrderDate Between #1/1/96# And #2/1/96#
3¡¢ ÁÐ±í£¨IN £¬NOT IN£©
IN ÔËËã·ûÓÃÀ´Æ¥ÅäÁбíÖеÄÈκÎÒ»¸öÖµ¡£IN×Ó¾ä¿ÉÒÔ´úÌæÓÃOR×Ó¾äÁ¬½ÓµÄÒ»Á¬´®µÄÌõ¼þ¡£
4¡¢ ģʽƥÅä(LIKE)
LIKEÔËËã·û¼ìÑéÒ»¸ö°üº¬×Ö·û´®Êý¾ÝµÄ×Ö¶ÎÖµÊÇ·ñÆ¥ÅäÒ»Ö¸¶¨Ä£Ê½¡£
ͨÅä·û º¬Ò壺
£¿ ÈκÎÒ»¸öµ¥Ò»µÄ×Ö·û
* ÈÎÒⳤ¶ÈµÄ×Ö·û
# 0~9Ö®¼äµÄµ¥Ò»Êý×Ö
[×Ö·ûÁбí] ÔÚ×Ö·ûÁбíÀïµÄÈÎÒ»Öµ
[£¡×Ö·ûÁбí] ²»ÔÚ×Ö·ûÁбíÀïµÄÈÎÒ»Öµ
- Ö¸¶¨×Ö·û·¶Î§£¬Á½±ßµÄÖµ·Ö±ðΪÆäÉÏÏÂÏÞ
Èý .ÓÃORDER BY×Ó¾äÅÅÐò½á¹û
ORDER×Ӿ䰴һ¸ö»ò¶à¸ö£¨×î¶à16¸ö£©×Ö¶ÎÅÅÐò²éѯ½á¹û£¬¿ÉÒÔÊÇÉýÐò£¨ASC£©Ò²¿ÉÒÔÊǽµÐò£¨DESC£©£¬È±Ê¡ÊÇÉýÐò¡£ORDER×Ó¾äͨ³£·ÅÔÚSQLÓï¾äµÄ×îºó¡£
ORDER×Ó¾äÖж¨ÒåÁ˶à¸ö×ֶΣ¬Ôò°´ÕÕ×ֶεÄÏȺó˳ÐòÅÅÐò¡£
Àý£º
SELECT ProductName,UnitPrice, UnitInStock FROM Products ORDER BY UnitInStock DESC , UnitPrice DESC, ProductName
ORDER BY ×Ó¾äÖпÉÒÔÓÃ×Ö¶ÎÔÚÑ¡ÔñÁбíÖеÄλÖúŴúÌæ×Ö¶ÎÃû£¬¿ÉÒÔ»ìºÏ×Ö¶ÎÃûºÍλÖúš£
Àý£ºÏÂÃæµÄÓï¾ä²úÉúÓëÉÏÁÐÏàͬµÄЧ¹û¡£
SELECT ProductName,UnitPrice, UnitInStock FROM Products ORDER BY 1 DESC , 2 DESC,3
ËÄ .ÔËÓÃÁ¬½Ó¹ØÏµÊµÏÖ¶à±í²éѯ
Àý£ºÕÒ³öͬһ¸ö³ÇÊÐÖй©Ó¦É̺Ϳͻ§µÄÃû×Ö
SELECT Customers.CompanyName, Suppliers.ComPany.Name FROM Customers, Suppliers WHERE Customers.City=Suppliers.City
Àý£ºÕÒ³ö²úÆ·¿â´æÁ¿´óÓÚͬһÖÖ²úÆ·µÄ¶¨µ¥µÄÊýÁ¿µÄ²úÆ·ºÍ¶¨µ¥
SELECT ProductName,OrderID, UnitInStock, Quantity FROM Products, [Order Deails] WHERE Product.productID=[Order Details].ProductID
AND UnitsInStock>Quantity
ÁíÒ»ÖÖ·½·¨ÊÇÓà Microsof JET SQL ¶ÀÓÐµÄ JNNER JOIN
Óï·¨£º
FROM table1 INNER JOIN table2 ON table1.field1 comparision table2.field2
ÆäÖÐcomparision ¾ÍÊÇÇ°ÃæWHERE×Ó¾äÓõ½µÄ±È½ÏÔËËã·û¡£
SELECT FirstName,lastName,OrderID,CustomerID,OrderDate FROM Employees
INNER JOIN Orders ON Employees.EmployeeID=Orders.EmployeeID
×¢Ò⣺
INNER JOIN²»ÄÜÁ¬½ÓMemo OLE Object Single Double Êý¾ÝÀàÐÍ×ֶΡ£
ÔÚÒ»¸öJOINÓï¾äÖÐÁ¬½Ó¶à¸öON×Ó¾ä
Óï·¨£º
SELECT fields FROM table1 INNER JOIN table2
ON table1.field1 compopr table2.field1 AND
ON table1.field2 compopr table2.field2 OR
ON table1.field3 compopr table2.field3
Ò²¿ÉÒÔ   www.atcpu.com
£¨table2 INNER JOIN [( ]table3
[INNER JOER] [( ]tablex[INNER JOIN]
ÍⲿÁ¬½Ó·µ»Ø¸ü¶à¼Ç¼£¬ÔÚ½á¹ûÖб£Áô²»Æ¥ÅäµÄ¼Ç¼£¬²»¹Ü´æ²»´æÔÚÂú×ãÌõ¼þµÄ¼Ç¼¶¼Òª·µ»ØÁíÒ»²àµÄËùÓмǼ¡£
FROM table [LEFT|RIGHT]JOIN table2
ON table1.field1comparision table.field2
ÓÃ×óÁ¬½ÓÀ´½¨Á¢ÍⲿÁ¬½Ó£¬ÔÚ±í´ïʽµÄ×ó±ßµÄ±í»áÏÔʾÆäËùÓеÄÊý¾Ý
Àý£º²»¹ÜÓÐûÓж¨»õÁ¿£¬·µ»ØËùÓÐÉÌÆ·
SELECT ProductName ,OrderID
FROM Products
LEFT JOIN Orders ON Products.PrductsID=Orders.ProductID
ÓÒÁ¬½ÓÓë×óÁ¬½ÓµÄ²î±ðÔÚÓÚ£º²»¹Ü×ó²à±íÀïÓÐûÓÐÆ¥ÅäµÄ¼Ç¼£¬Ëü¶¼´Ó×ó²à±íÖзµ»ØËùÓмǼ¡£
Àý£ºÈç¹ûÏëÁ˽â¿Í»§µÄÐÅÏ¢£¬²¢Í³¼Æ¸÷¸öµØÇøµÄ¿Í»§·Ö²¼£¬Õâʱ¿ÉÒÔÓÃÒ»¸öÓÒÁ¬½Ó£¬¼´Ê¹Ä³¸öµØÇøÃ»Óпͻ§£¬Ò²Òª·µ»Ø¿Í»§ÐÅÏ¢¡£
¿ÕÖµ²»»áÏ໥ƥÅ䣬¿ÉÒÔͨ¹ýÍâÁ¬½Ó²ÅÄܲâÊÔ±»Á¬½ÓµÄij¸ö±íµÄ×Ö¶ÎÊÇ·ñÓпÕÖµ¡£
SELECT *
FROM talbe1
LEFT JOIN table2 ON table1.a=table2.c
1 Á¬½Ó²éѯÖÐʹÓÃIifº¯ÊýʵÏÖÒÔ0ÖµÏÔʾ¿ÕÖµ
Iif±í´ïʽ£º Iif(IsNull(Amount,0,Amout)
Àý£ºÎÞÂÛ¶¨»õ´óÓÚ»òСÓÚ£¤50£¬¶¼Òª·µ»ØÒ»¸ö±êÖ¾¡£
Iif([Amount]>50,?Big order?,?Small order?)
  www.atcpu.com
Îå. ·Ö×éºÍ×ܽá²éѯ½á¹û
ÔÚSQLµÄÓï·¨ÀGROUP BYºÍHAVING×Ó¾äÓÃÀ´¶ÔÊý¾Ý½øÐлã×Ü¡£GROUP BY×Ó¾äÖ¸Ã÷Á˰´ÕÕÄö×Ö¶ÎÀ´·Ö×飬¶ø½«¼Ç¼·Ö×éºó£¬ÓÃHAVING×Ó¾ä¹ýÂËÕâЩ¼Ç¼¡£
GROUP BY ×Ó¾äµÄÓï·¨
SELECT fidldlist
FROM table
WHERE criteria
[GROUP BY groupfieldlist [HAVING groupcriteria]]
×¢£ºMicrosoft JetÊý¾Ý¿â Jet ²»ÄܶԱ¸×¢»òOLE¶ÔÏó×ֶηÖ×é¡£
GROUP BY×Ö¶ÎÖеÄNullÖµÒÔ±¸·Ö×鵫ÊDz»Äܱ»Ê¡ÂÔ¡£
ÔÚÈκÎSQLºÏ¼Æº¯ÊýÖв»¼ÆËãNullÖµ¡£
GROUP BY×Ó¾äºó×î¶à¿ÉÒÔ´øÓÐÊ®¸ö×ֶΣ¬ÅÅÐòÓÅÏȼ¶°´´Ó×óµ½ÓÒµÄ˳ÐòÅÅÁС£
Àý£ºÔÚ¡®WA¡¯µØÇøµÄ¹ÍÔ±±íÖа´Í·ÏηÖ×éºó£¬ÕÒ³ö¾ßÓÐͬµÈÍ·ÏεĹÍÔ±ÊýÄ¿´óÓÚ1È˵ÄËùÓÐÍ·ÏΡ£
SELECT Title ,Count(Title) as Total
FROM Employees
WHERE Region = ¡®WA¡¯
GROUP BY Title
HAVING Count(Title)>1
JET SQL Öеľۻýº¯Êý
¾Û¼¯º¯Êý ÒâÒå
SUM ( ) ÇóºÍ
AVG ( ) ƽ¾ùÖµ
COUNT ( ) ±í´ïʽÖмǼµÄÊýÄ¿
COUNT (* ) ¼ÆËã¼Ç¼µÄÊýÄ¿
MAX ×î´óÖµ   www.atcpu.com
MIN ×îСֵ
VAR ·½²î
STDEV ±ê×¼Îó²î
FIRST µÚÒ»¸öÖµ
LAST ×îºóÒ»¸öÖµ
Áù. ÓÃParametersÉùÃ÷´´½¨²ÎÊý²éѯ
ParametersÉùÃ÷µÄÓï·¨:
PARAMETERS name datatype[,name datatype[, ¡­]]
ÆäÖÐname ÊDzÎÊýµÄ±êÖ¾·û,¿ÉÒÔͨ¹ý±êÖ¾·û²ÎÊý.
Datatype˵Ã÷²ÎÊýµÄÊý¾ÝÀàÐÍ.
ʹÓÃʱҪ°ÑPARAMETERS ÉùÃ÷ÖÃÓÚÈÎºÎÆäËûÓï¾ä֮ǰ.
Àý:
PARAMETERS[Low price] Currency,[Beginning date]datatime
SELECT OrderID ,OrderAmount FROM Orders WHERE OrderAMount>[low price] AND OrderDate>=[Beginning date]
Æß. ¹¦Äܲéѯ
Ëùν¹¦Äܲéѯ,ʵ¼ÊÉÏÊÇÒ»ÖÖ²Ù×÷²éѯ,Ëü¿ÉÒÔ¶ÔÊý¾Ý¿â½øÐпìËÙ¸ßЧµÄ²Ù×÷.ËüÒÔÑ¡Ôñ²éѯΪĿµÄ,ÌôÑ¡³ö·ûºÏÌõ¼þµÄÊý¾Ý,ÔÙ¶ÔÊý¾Ý½øÐÐÅú´¦Àí.¹¦Äܲéѯ°üÀ¨¸üвéѯ,ɾ³ý²éѯ,Ìí¼Ó²éѯ,ºÍÉú³É±í²éѯ.
1¡¢¸üвéѯ
UPDATE×Ó¾ä¿ÉÒÔͬʱ¸ü¸ÄÒ»¸ö»ò¶à¸ö±íÖеÄÊý¾Ý.ËüÒ²¿ÉÒÔͬʱ¸ü¸Ä¶à¸ö×ֶεÄÖµ.
¸üвéѯÓï·¨:
UPDATE ±íÃû SET ÐÂÖµ WHERE ×¼Ôò
Àý:Ó¢¹ú¿Í»§µÄ¶¨»õÁ¿Ôö¼Ó5%,»õÔËÁ¿Ôö¼Ó3%
UPDATE OEDERS SET OrderAmount = OrderAmount *1.1 Freight = Freight*1.03 WHERE ShipCountry = ¡®UK¡¯
2¡¢ ɾ³ý²éѯ
DELETE×Ó¾ä¿ÉÒÔʹÓû§É¾³ý´óÁ¿µÄ¹ýʱµÄ»òÈßÓÚµÄÊý¾Ý.
×¢:ɾ³ý²éѯµÄ¶ÔÏóÊÇÕû¸ö¼Ç¼.
DELETE×Ó¾äµÄÓï·¨:   www.atcpu.com
DELETE [±íÃû.*] FROM À´Ô´±í WHERE ×¼Ôò
Àý: Ҫɾ³ýËùÓÐ94ÄêǰµÄ¶¨µ¥
DELETE * FROM Orders WHERE OrderData<#94-1-1#
3¡¢ ×·¼Ó²éѯ
INSERT×Ó¾ä¿ÉÒÔ½«Ò»¸ö»òÒ»×é¼Ç¼׷¼Óµ½Ò»¸ö»ò¶à¸ö±íµÄβ²¿.
INTO ×Ó¾äÖ¸¶¨½ÓÊÜмǼµÄ±í
valueS ¹Ø¼ü×ÖÖ¸¶¨Ð¼Ç¼Ëù°üº¬µÄÊý¾ÝÖµ.
INSERT ×Ó¾äµÄÓï·¨:
INSETR INTO Ä¿µÄ±í»ò²éѯ(×Ö¶Î1,×Ö¶Î2,¡­) valueS(ÊýÖµ1,ÊýÖµ2,¡­)
Àý:Ôö¼ÓÒ»¸ö¿Í»§
INSERT INTO Employees(FirstName,LastName,title) valueS(¡®Harry¡¯,¡¯Washington¡¯,¡¯Trainee¡¯)
4¡¢ Éú³É±í²éѯ
¿ÉÒÔÒ»´ÎÐԵذÑËùÓÐÂú×ãÌõ¼þµÄ¼Ç¼¿½±´µ½Ò»ÕÅбíÖÐ.ͨ³£ÖÆ×÷¼Ç¼µÄ±¸·Ý»ò¸±±¾»ò×÷Ϊ±¨±íµÄ»ù´¡.
SELECT INTO×Ó¾äÓÃÀ´´´½¨Éú³É±í²éѯÓï·¨:
SELECT ×Ö¶Î1,×Ö¶Î2,¡­ INTO бí[IN ÍⲿÊý¾Ý¿â] FROM À´Ô´Êý¾Ý¿â WHERE ×¼Ôò
Àý:Ϊ¶¨µ¥ÖÆ×÷Ò»¸ö´æµµ±¸·Ý
SELECT * INTO OrdersArchive FROM Orders
°Ë. ÁªºÏ²éѯ
UNIONÔËËã¿ÉÒ԰Ѷà¸ö²éѯµÄ½á¹ûºÏ²¢µ½Ò»¸ö½á¹û¼¯ÀïÏÔʾ.
UNIONÔËËãµÄÒ»°ãÓï·¨:
[±í]²éѯ1 UNION [ALL]²éѯ2 UNION ¡­
Àý:·µ»Ø°ÍÎ÷ËùÓй©¸øÉ̺Ϳͻ§µÄÃû×ֺͳÇÊÐ
SELECT CompanyName,City FROM Suppliers WHERE Country = ¡®Brazil¡¯
UNION
SELECT CompanyName,City FROM Customers WHERE Country = ¡®Brazil¡¯
ȱʡµÄÇé¿öÏÂ,UNION×Ӿ䲻·µ»ØÖظ´µÄ¼Ç¼.Èç¹ûÏëÏÔʾËùÓмǼ,¿ÉÒÔ¼ÓALLÑ¡Ïî
UNIONÔËËãÒªÇó²éѯ¾ßÓÐÏàͬÊýÄ¿µÄ×Ö¶Î.µ«ÊÇ,×Ö¶ÎÊý¾ÝÀàÐͲ»±ØÏàͬ.
ÿһ¸ö²éѯ²ÎÊýÖпÉÒÔʹÓÃGROUP BY ×Ó¾ä »ò HAVING ×Ӿ佸ÐзÖ×é.ÒªÏëÒÔÖ¸¶¨µÄ˳ÐòÀ´ÏÔʾ·µ»ØµÄÊý¾Ý,¿ÉÒÔÔÚ×îºóÒ»¸ö²éѯµÄβ²¿Ê¹ÓÃOREER BY×Ó¾ä.
¾Å. ½»²æ²éѯ
½»²æ²éѯ¿ÉÒÔ¶ÔÊý¾Ý½øÐÐ×ܺÍ,ƽ¾ù,¼ÆÊý»òÆäËû×ܺͼÆËã·¨µÄ¼ÆËã,ÕâЩÊý¾Ýͨ¹ýÁ½ÖÖÐÅÏ¢½øÐзÖ×é:Ò»¸öÏÔʾÔÚ±íµÄ×ó²¿,ÁíÒ»¸öÏÔʾÔÚ±íµÄ¶¥²¿.
Microsoft Jet SQL ÓÃTRANSFROMÓï¾ä´´½¨½»²æ±í²éѯÓï·¨:
TRANSFORM aggfunction   www.atcpu.com
SELECT Óï¾ä
GROUP BY ×Ó¾ä
PIVOT pivotfield[IN(value1 [,value2[,¡­]]) ]
AggfounctionÖ¸SQL¾Û»ýº¯Êý,
SELECTÓï¾äÑ¡Ôñ×÷Ϊ±êÌâµÄµÄ×Ö¶Î,
GROUP BY ·Ö×é
˵Ã÷£º
Pivotfield ÔÚ²éѯ½á¹û¼¯Öд´½¨ÁбêÌâʱÓõÄ×ֶλò±í´ïʽ,ÓÿÉÑ¡µÄIN×Ó¾äÏÞÖÆËüµÄȡֵ.
value´ú±í´´½¨ÁбêÌâµÄ¹Ì¶¨Öµ.
Àý:ÏÔʾÔÚ1996ÄêÀïÿһ¼¾¶ÈÿһλԱ¹¤Ëù½ÓµÄ¶¨µ¥µÄÊýÄ¿:
TRANSFORM Count(OrderID)
SELECT FirstName;¡¯¡¯;LastName AS FullName FROM Employees INNER JOIN Orders
ON Employees.EmployeeID = Orders.EmployeeID WHERE DatePart(¡°yyyy¡±,OrderDate)= ¡®1996¡¯
GROUP BY FirstName;¡¯¡¯;LastName
ORDER BY FirstName;¡¯¡¯;LastName
POVOT DatePart(¡°q¡±,OrderDate);¡¯¼¾¶È¡¯
Ê® .×Ó²éѯ
×Ó²éѯ¿ÉÒÔÀí½âΪ Ìײéѯ.×Ó²éѯÊÇÒ»¸öSELECTÓï¾ä.
1¡¢ ±í´ïʽµÄÖµÓë×Ó²éѯ·µ»ØµÄµ¥Ò»Öµ×ö±È½Ï
Óï·¨:
±í´ïʽ comparision [ANY|ALL|SOME](×Ó²éѯ)
˵Ã÷£º
ANY ºÍSOMEν´ÊÊÇͬÒå´Ê,Óë±È½ÏÔËËã·û(=,<,>,<>,<=,>=)Ò»ÆðʹÓÃ.·µ»ØÒ»¸ö²¼¶ûÖµTrue»ò False.ANYµÄÒâ˼ÊÇ,±í´ïʽÓë×Ó²éѯ·µ»ØµÄһϵÁеÄÖµÖðÒ»±È½Ï,Ö»ÒªÆäÖеÄÒ»´Î±È½Ï²úÉúTrue½á¹û,ANY²âÊԵķµ»Ø TrueÖµ(¼ÈWHERE×Ó¾äµÄ½á¹û),¶ÔÓ¦Óڸñí´ïʽµÄµ±Ç°¼Ç¼½«½øÈëÖ÷²éѯµÄ½á¹ûÖÐ.ALL²âÊÔÔòÒªÇó±í´ïʽÓë×Ó²éѯ·µ»ØµÄһϵÁеÄÖµµÄ±È½Ï¶¼²úÉú True½á¹û,²Å»Ø·µ»ØTrueÖµ.
Àý:Ö÷²éѯ·µ»Øµ¥¼Û±ÈÈκÎÒ»¸öÕÛ¿Û´óÓÚµÈÓÚ25%µÄ²úÆ·µÄµ¥¼ÛÒª¸ßµÄËùÓвúÆ·
SELECT * FROM Products WHERE UnitPrice>ANY (SELECT UnitPrice FROM[Order Details] WHERE Discount>0.25)
2¡¢ ¼ì²é±í´ïʽµÄÖµÊÇ·ñÆ¥Åä×Ó²éѯ·µ»ØµÄÒ»×éÖµµÄij¸öÖµ
Óï·¨:   www.atcpu.com
[NOT]IN(×Ó²éѯ)
Àý:·µ»Ø¿â´æ¼ÛÖµ´óÓÚµÈÓÚ1000µÄ²úÆ·.
SELECT ProductName FROM Products WHERE ProductID IN (SELECT PrdoctID FROM [Order DEtails] WHERE UnitPrice*Quantity>= 1000)
3¡¢¼ì²â×Ó²éѯÊÇ·ñ·µ»ØÈκμǼ
Óï·¨:
[NOT]EXISTS (×Ó²éѯ)
Àý:ÓÃEXISTS¼ìË÷Ó¢¹úµÄ¿Í»§
SELECT ComPanyName,ContactName FROM Orders WHERE EXISTS (SELECT * FROM Customers WHERE Country = ¡®UK¡¯ AND Customers.CustomerID= Orders.CustomerID)
ϲ»¶0 ÆÀ·Ö0
ÓοÍ
·µ»Ø¶¥²¿
