阅读:2828回复:0
[mysql]Linux下MYSQL安装和基本管理
更多 发布于:2012-09-01 02:20
Linux下MYSQL安装和基本管理
安装linux一些必须的包:
[plain]
yum install gcc gcc-c++ gcc-g77 autoconf automake zlib* fiex* libxml* ncurses-devel libmcrypt* libtool-ltdl-devel* libevent
安装mysql,mysql安装包需要自己下载,安装目录 /usr/local/web/
[plain]
sudo mkdir -p /usr/local/web/
sudo tar xzvf mysql-5.1.39.tar.gz
cd mysql-5.1.39     www.atcpu.com
./configure --prefix=/usr/local/web/mysql.5.1.39 --enable-thread-safe-client --enable-assembler --with-big-tables --with-client-ldflags=-all-static --with-mysqld-ldflags=-all-static --with-charset=utf8 --with-collation=utf8_general_ci --with-extra-charsets=complex
make
make install
创建mysql用户组等信息
[plain]
sudo  groupadd mysql
sudo  useradd -g mysql -s /sbin/nologin mysql
sudo ./scripts/mysql_install_db --user=mysql --datadir=/usr/local/web/mysql.5.1.39/var     www.atcpu.com
sudo  chown -R root /usr/local/web/mysql.5.1.39
sudo  chown -R mysql:mysql /usr/local/web/mysql.5.1.39/var
管理MYSQL
[plain]
#启动mysql:
sudo  /usr/local/web/mysql.5.1.39/share/mysql/mysql.server  start
#重启mysql
sudo  /usr/local/web/mysql.5.1.39/share/mysql/mysql.server  restart
#停止mysql
sudo  /usr/local/web/mysql.5.1.39/share/mysql/mysql.server  stop
