阅读:3086回复:0
[SQL Server]SQL SERVER 2012 COLUMNSTORE INDEX-之一
更多 发布于:2012-09-04 18:05
作为 SQL SERVER 2012 一大卖点的 CLOUMNSTORE INDEX,先来认识一下。
1,支持数据类型:
int, big int, small int, tiny int, money, smallmoney, bit, float, real, char(n), varchar(n), nchar(n), nvarchar(n), date, datetime, datetime2, small datetime, time, datetimeoffset with precision <=2, decimal or numeric with precision <= 18
2,不支持数据类型:
decimal or numeric with precision > 18, datetimeoffset with precision > 2, binary, varbinary, image, text, ntext, varchar(max), nvarchar(max), cursor, hierarchyid, timestamp, uniqueidentifier, sqlvariant, xml.  www.atcpu.com
3,不可以用于:
INSERT, UPDATE, DELETE, MERGE
需要
[sql]
ALTER INDEX mycolumnstoreindex ON mytable DISABLE;
ALTER INDEX mycolumnstoreindex ON mytable REBUILD;
4,增加内存
[sql]
ALTER WORKLOAD GROUP [DEFAULT] WITH (REQUEST_MAX_MEMORY_GRANT_PERCENT=X)
ALTER RESOURCE GOVERNOR RECONFIGURE
GO
--where X is the percent, say 50.
5,查询索引大小:
[sql]
-- total size
with total_segment_size as (
    SELECT
        SUM (css.on_disk_size)/1024/1024 AS segment_size_mb
    FROM sys.partitions AS p
    www.atcpu.com
    JOIN sys.column_store_segments AS css
        ON p.hobt_id = css.hobt_id
total_dictionary_size as (
    SELECT SUM (csd.on_disk_size)/1024/1024 AS dictionary_size_mb
    JOIN sys.column_store_dictionaries AS csd
        ON p.hobt_id = csd.hobt_id
select
    segment_size_mb,
    dictionary_size_mb,
    segment_size_mb + isnull(dictionary_size_mb, 0) as total_size_mb
from total_segment_size
left outer join total_dictionary_size
    on 1 = 1
go
-- size per index
with segment_size_by_index AS (
SELECT
    p.object_id as table_id,
    p.index_id as index_id,
    www.atcpu.com
group by p.object_id, p.index_id
dictionary_size_by_index AS (
SELECT
select
    object_name(s.table_id) table_name,
    i.name as index_name,
    s.segment_size_mb,
    d.dictionary_size_mb,
    s.segment_size_mb + isnull(d.dictionary_size_mb, 0) as total_size_mb
from segment_size_by_index s
JOIN sys.indexes AS i
    ON i.object_id = s.table_id
    and i.index_id = s.index_id
left outer join dictionary_size_by_index d
    www.atcpu.com
    on s.table_id = s.table_id
    and s.index_id = d.index_id
order by total_size_mb desc
go
-- size per table
with segment_size_by_table AS (
SELECT
dictionary_size_by_table AS (
SELECT
    p.object_id AS table_id,
    www.atcpu.com
select
    t.name AS table_name,
    s.segment_size_mb,
from dictionary_size_by_table d
JOIN sys.tables AS t
    ON t.object_id = d.table_id
left outer join segment_size_by_table s
on d.table_id = s.table_id
go
-- size per column
    www.atcpu.com
with segment_size_by_column as (
    SELECT
        css.column_id,
        SUM (css.on_disk_size)/1024/1024.0 AS segment_size_mb
    GROUP BY p.object_id, css.column_id
dictionary_size_by_column as (
    SELECT
        www.atcpu.com
        csd.column_id,
        SUM (csd.on_disk_size)/1024/1024.0 AS dictionary_size_mb
    GROUP BY p.object_id, csd.column_id
select
    t.name as table_name,
    c.name as column_name,
    s.segment_size_mb,
    www.atcpu.com
    s.segment_size_mb + isnull(d.dictionary_size_mb, 0) total_size_mb
from segment_size_by_column s
join sys.tables AS t
    ON t.object_id = s.table_id
join sys.columns AS c
    ON c.object_id = s.table_id
    and c.column_id = s.column_id
left outer join dictionary_size_by_column d
    www.atcpu.com
    on s.table_id = d.table_id
    and s.column_id = d.column_id
go
