阅读:2547回复:0
[SQL Server]SQLSERVER CLR无序自增(支持并发)性能对比
更多 发布于:2012-09-04 18:06
CLR函数脚本
using System;
using System.Data;
using System.Data.SqlClient;
using System.Data.SqlTypes;
using Microsoft.SqlServer.Server;
using System.Collections;
/// <summary>  www.atcpu.com
/// 用户自定CLR 函数,用来生成一个序列
/// </summary>
public partial class test
    public static Hashtable ht=new Hashtable(); //创建一个Hashtable实例
    [Microsoft.SqlServer.Server.SqlFunction]
    public static SqlInt64 GetRowNum(SqlGuid Guid1)
        try
            if (!ht.Contains(Guid1)) //判断哈希表是否包含特定键,其返回值为true或false
                ht[Guid1] = 0;
            Int64 i = Convert.ToInt64(ht[Guid1].ToString());
            i++;
            ht[Guid1] = i.ToString();
            return i;
        catch
            return -1;
    /// <summary>
    /// 删除哈希表值
    /// </summary>
    /// <param name="Guid1"></param>
    [Microsoft.SqlServer.Server.SqlProcedure ]
    public static void ClearGuid(SqlGuid Guid1)
    {  www.atcpu.com
        try
            ht.Remove(Guid1);
            return ;
        catch
启动CLR
exec sp_configure 'show advanced options','1';
go
reconfigure  WITH OVERRIDE
go
exec sp_configure 'clr enabled','1'
go
ALTER DATABASE   test SET TRUSTWORTHY On
  www.atcpu.com
drop FUNCTION  GetRowNum
drop proc ClearGuid
drop ASSEMBLY testss
CREATE ASSEMBLY testss FROM 'C:\Documents and Settings\Administrator\桌面\test\SqlServerProject1\SqlServerProject1\bin\Debug\SqlServerProject1.dll' WITH PERMISSION_SET = UnSAFE;
go
创建函数
CREATE FUNCTION dbo.GetRowNum
@Guid uniqueidentifier
RETURNS bigint
AS EXTERNAL NAME
  testss.test.GetRowNum
CREATE proc ClearGuid
AS EXTERNAL NAME
  testss.test.ClearGuid
GetRowNum与identity对比
declare @Guid uniqueidentifier
set @Guid=newid()  www.atcpu.com
select dbo.GetRowNum(@Guid)
  from list
--清理哈希表
exec ClearGuid  @Guid
select identity(int ,1,1) as id into #t  from list
select id  from #t
drop table #t
数据量943761
   www.atcpu.com
时间匆忙,经多次测试,初步结果
1.GetRowNum(5591)消耗时间比identity(6278)少近700毫秒
2.GetRowNum(2171)的cpu比identity(922)高很多
3.GetRowNum(2352)读是identity(4828)的一半
4.GetRowNum没有写入,identity的写入是1519
初步结论
1.GetRowNum消耗更多的CPU,进行运算
2.GetRowNum的磁盘消耗比identity低,而且是没有写入的
3.如果表已经有自增(不连续),identity就不能用,GetRowNum可以
4.GetRowNum瞬间返回数据,identity要停顿
