阅读:4963回复:0
Android中SMS的接收处理
更多 发布于:2012-09-06 13:42
在解析WAPPUSH over SMS时,看了一下Android里SMS接收的流程,并按照自己需要的流程记录,其他分支的详细处理并未讲述。PDU数据的encode/decode也并未在本文中进行解析,有兴趣的读者可以到相应的代码处自己解读一下。
Android中,RIL用RILReciever接收SMS pdu,并根据不同的信息类型用相应函数来处理。因手机制式的差异,用GsmSmsDispatcher或CdmaSmsDispatcher来做各自的消息处理并分发。最后的分发是通过发送相应的Broadcast,所以,对感兴趣的消息处理,可以注册Receiver来监听相应的Broadcast,实现自己的SMS/MMS/Wap push,以及其他类型消息的接收处理。
RIL构造函数中,Receiver的初始化[在文件RIL.java中]
[java]
mReceiver = newRILReceiver();
mReceiverThread =new Thread(mReceiver, "RILReceiver");
mReceiverThread.start();
其中的类型
mReceiver: RILReceiver
mReceiverThread: Thread
RILReceiver实现了Runnable
关注RILReceiver线程的实现[在RILReceiver::run()中]
[java] public void run() {
    int retryCount= 0;
    try {for (;;) {
        LocalSockets = null;
        LocalSocketAddress l;
        try {
            s = newLocalSocket();
            l = newLocalSocketAddress(SOCKET_NAME_RIL,
                   LocalSocketAddress.Namespace.RESERVED);
            s.connect(l);
        } catch (IOException ex){
        retryCount= 0;
        mSocket =s;
        int length= 0;
        try {
            InputStreamis = mSocket.getInputStream();
            for(;;) {
               Parcel p;
               length = readRilMessage(is, buffer);
                if(length < 0) {
                   // End-of-stream reached
                   break;
                p =Parcel.obtain();
               p.unmarshall(buffer, 0, length);
               p.setDataPosition(0);
                processResponse(p);
               p.recycle();
        } catch(java.io.IOException ex) {
        } catch(Throwable tr) {
    }} catch(Throwable tr) {
       Log.e(LOG_TAG,"Uncaught exception", tr);
        public void run() {
            int retryCount= 0;
            try {for (;;) {
                try {
                    s.connect(l);
                retryCount= 0;
                mSocket =s;
                int length= 0;
                try {
                    for(;;) {
                       Parcel p;
                        if(length < 0) {
                           break;
                        p =Parcel.obtain();
                        processResponse(p);
                       p.recycle();
RILReceiver线程不停的监听本地Socket,读到数据之后在processResponse()[Line#37]中处理。
[java] private void processResponse (Parcel p) {
    int type;
    type = p.readInt();
     if(type == RESPONSE_UNSOLICITED) {
        processUnsolicited (p);
     }else if (type == RESPONSE_SOLICITED) {
        processSolicited (p);
    releaseWakeLockIfDone();
       int type;
       type = p.readInt();
如果类型属于Unsolicited消息,则在processUnsolicited()中处理。收到的短信是属于Unsolicited信息,看它的实现。
processUnsolicited()中很长的switch… case语句中对收到短信的处理在case RIL_UNSOL_RESPONSE_NEW_SMS:
[java] SmsMessage sms;
sms = SmsMessage.newFromCMT(a);
if (mSMSRegistrant != null) {
     mSMSRegistrant.notifyRegistrant(new AsyncResult(null, sms, null));
              SmsMessage sms;
这里的SmsMessage是Android.telephony.SmsMessage。newFromCMT()中会根据电话类型(GSM/CDMA)选择具体的SmsMessage进行封装(因为Rational Rose中,同一工程中,不同包内的类也不允许同名,com.Android.internal.telephony.gsm.SmsMessage用gsm.SmsMessage代替;com.Android.internal.telephony.cdma.SmsMessage用cdma.SmsMessage代替。实际类型都是SmsMessage)。
mSMSRegistrant是RIL父类的成员。通过setOnNewSMS()/unSetOnNewSMS()设置和取消设置。SMSDispatcher的构造函数中注册了SMS的Registrant
mCm.setOnNewSMS(this, EVENT_NEW_SMS, null);
所以,调用mSMSRegistrant.notifyRegistrant(newAsyncResult(null, sms, null))之后,执行的是SMSDispatcher中Handler在handleMessage()中对EVENT_NEW_SMS的处理:
ar = (AsyncResult) msg.obj;
if (ar.exception != null) {
    Log.e(TAG, "Exception processing incoming SMS. Exception:" +ar.exception);
    return;
sms = (SmsMessage) ar.result;
try {
    int result = dispatchMessage(sms.mWrappedSmsMessage);
    if (result != Activity.RESULT_OK) {
         // RESULT_OK means thatmessage was broadcast for app(s) to handle.
         // Any other result, weshould ack here.
         boolean handled = (result== Intents.RESULT_SMS_HANDLED);
        notifyAndAcknowledgeLastIncomingSms(handled, result, null);
} catch (RuntimeException ex) {
    Log.e(TAG, "Exception dispatching message", ex);
    notifyAndAcknowledgeLastIncomingSms(false,Intents.RESULT_SMS_GENERIC_ERROR, null);
           SmsMessage sms;
               return;
           try {
SMSDispatcher是一个abstract的类,dispatchMessage()的具体实现在GsmSMSDispatcher或CdmaSMSDispatcher中。
GsmSMSDispatcher::dispatchMessage()中,会对Class 0类型的短信,有目标端口的短信,和长短信做处理。
目标端口为WAPPUSH的信息,则调用mWapPush.dispatchWapPdu(sms.getUserData(),pdus)让WAPPUSH来处理;其它未知的端口,则用“sms://localhost:<port>”指定端口。
对长短信,调用processMessagePart()进行组合处理。
1)      有目标端口且目标端口是WAP PUSH(SmsHeader.PORT_WAP_PUSH)的信息,用WapPushOverSms::dispatchWapPdu()来处理:
根据不同的contentType:
-> dispatchWapPdu_PushCO();
-> dispatchWapPdu_MMS();
-> dispatchWapPdu_default()
2)      有目标地址且目标端口不是WAP PUSH的信息,在SMSDispatcher::dispatchPortAddressedPdus()中处理:
       Uri uri =Uri.parse("sms://localhost:" + port);
        Intent intent= new Intent(Intents.DATA_SMS_RECEIVED_ACTION, uri);
       intent.putExtra("pdus", pdus);
       dispatch(intent, "Android.permission.RECEIVE_SMS");
3)      通常的无目标地址的信息(普通短信),在SMSDispatcher::dispatchPdus()中处理:
        Intent intent= new Intent(Intents.SMS_RECEIVED_ACTION);
