阅读:4006回复:0
android学习笔记30--------------聊天式对话效果
更多 发布于:2012-09-06 13:43
这几天看了些聊天式对话效果,自己修改了一番。
public class ChatActivity extends Activity
    private ListView talkView;
    private Button messageButton;
    private EditText messageText;
    private ArrayList<ChatMessage> list = new ArrayList<ChatMessage>();
    @Override
    public void onCreate(Bundle savedInstanceState)
        init();
    private void init()
        talkView = (ListView) findViewById(R.id.list);
        messageButton = (Button) findViewById(R.id.MessageButton);
        messageText = (EditText) findViewById(R.id.MessageText);
        messageButton.setOnClickListener(new OnClickListener()
            @Override
            public void onClick(View v)
                String date = getDate();
                String msgText = getText();
                int RIdA = R.layout.chatting_item_from;
                ChatMessage newMsg = new ChatMessage( date, msgText, RIdA);
                list.add(newMsg);
                int RIdB = R.layout.chatting_item_to;
                ChatMessage backMsg = new ChatMessage(date,
                        "自动回复(for test!)", RIdB);
                list.add(backMsg);
                talkView
                        .setAdapter(new ChattingAdapter(ChatActivity.this, list));
                messageText.setText("");
    private String getDate()
        SimpleDateFormat sdf = new SimpleDateFormat("MM-dd HH:mm");
        Date d = new Date();
        return sdf.format(d);
    private String getText()
        return messageText.getText().toString();
@Override
  init();
private void init()
   @Override
    list.add(newMsg);
    list.add(backMsg);
    talkView
[java]
public class ChatMessage
    private String date;
    private String text;
    private int layoutID;
    public ChatMessage(String date, String text, int id)
        this.date = date;
        this.text = text;
        this.layoutID = id;
    public String getDate()
        return date;
    public void setDate(String date)
        this.date = date;
    public String getText()
        return text;
    public void setText(String text)
        this.text = text;
    public int getLayoutID()
        return layoutID;
    public void setLayoutID(int layoutID)
        this.layoutID = layoutID;
  this.date = date;
  this.text = text;
  this.layoutID = id;
  return date;
  this.date = date;
  return text;
  this.text = text;
  return layoutID;
[java]
public class ChattingAdapter extends BaseAdapter
    //private static final String TAG = ChattingAdapter.class.getSimpleName();
    private ArrayList<ChatMessage> list;
    private Context context;
    public ChattingAdapter(Context context, ArrayList<ChatMessage> list)
        this.context = context;
        this.list = list;
    public boolean areAllItemsEnabled()
        return false;
    public boolean isEnabled(int arg0)
        return false;
    @Override
    public int getCount()
        // TODO Auto-generated method stub
        return list.size();
    @Override
    public Object getItem(int position)
        return list.get(position);
    @Override
    public long getItemId(int position)
        return position;
    public int getItemViewType(int position)
        return position;
    @Override
    public View getView(int position, View convertView, ViewGroup parent)
        ChatMessage msg = list.get(position);
        int itemlayout = msg.getLayoutID();
        LinearLayout layout = new LinearLayout(context);
        LayoutInflater vi = (LayoutInflater) context
                .getSystemService(Context.LAYOUT_INFLATER_SERVICE);
        vi.inflate(itemlayout, layout, true);
        TextView tvDate = (TextView) layout
                .findViewById(R.id.messagedetail_row_date);
        tvDate.setText(msg.getDate());
        TextView tvText = (TextView) layout
                .findViewById(R.id.messagedetail_row_text);
        tvText.setText(msg.getText());
        return layout;
    public int getViewTypeCount()
        return list.size();
    public boolean hasStableIds()
        return false;
    public boolean isEmpty()
        return false;
    public void registerDataSetObserver(DataSetObserver observer)
    public void unregisterDataSetObserver(DataSetObserver observer)
  this.list = list;
  return false;
  return false;
@Override
  return list.size();
@Override
@Override
  return position;
  return position;
@Override
  return layout;
  return list.size();
  return false;
  return false;
[java]
<?xml version="1.0" encoding="UTF-8"?>
<LinearLayout Android:orientation="vertical" Android:paddingLeft="6.0dip" Android:paddingRight="6.0dip" Android:layout_width="fill_parent" Android:layout_height="wrap_content"
  xmlns:Android="http://schemas.Android.com/apk/res/Android">
<LinearLayout
      Android:layout_width="wrap_content"
      Android:background="@drawable/chatto"
      Android:layout_marginLeft="25px"
      Android:layout_gravity="right">
          <TextView
            Android:id="@+id/messagedetail_row_text"
            Android:paddingLeft="2px"
            Android:textColor="#0000DD"
            Android:textSize="16dip"
            Android:layout_gravity="left"/>
          <TextView
              Android:id="@+id/messagedetail_row_date"
              Android:textColor="#000000"
              Android:paddingTop="2px"
              Android:textSize="12dip"
              Android:layout_marginLeft="60dip"
              Android:layout_gravity="right"/>
  </LinearLayout>
</LinearLayout>
<LinearLayout
     <TextView
          <TextView
  </LinearLayout>
</LinearLayout>
[java]
<LinearLayout
    Android:layout_height="fill_parent">
    <LinearLayout
      Android:background="@drawable/chatfrom"
      Android:layout_marginLeft="5dp"
      Android:layout_gravity="left">
          <TextView
          <TextView
          </LinearLayout>
</LinearLayout>
<LinearLayout
    <LinearLayout
          <TextView
          <TextView
          </LinearLayout>
</LinearLayout>
[java]
<LinearLayout
    <RelativeLayout
        Android:id="@+id/linearLayout1">
    <ListView
        Android:id="@+id/list"
        Android:layout_height="380px"
        Androidcrollbars="none"
        ></ListView>
        <EditText
        Android:id="@+id/MessageText"
        Android:hint="点击输入信息:"
        Android:layout_alignParentBottom="true"
        Android:layout_alignParentLeft="true"
        Android:layout_alignRight="@+id/nulltext"
        ></EditText>
        <TextView
            Android:id="@+id/nulltext"
            Android:layout_below="@+id/list"
            Android:layout_toLeftOf ="@+id/MessageButton"
            ></TextView>
       <Button
         Android:id="@+id/MessageButton"
         Android:text="发送"
         Android:layout_alignTop="@+id/nulltext"
         Android:layout_alignParentRight="true"
        ></Button>
    </RelativeLayout>
</LinearLayout>
