阅读:2782回复:0
Android开发教程之--sql语句
更多 发布于:2012-09-06 13:51
一、创建/删除表
String sql="Create table "+TABLE_NAME+"("+FIELD_ID+" integer primary key autoincrement,"  +FIELD_TITLE+" text );";
        db.execSQL(sql);
String sql=" DROP TABLE IF EXISTS "+TABLE_NAME;
        db.execSQL(sql);
二、查询
从表中查询数据(in)   SELECT * FROM meta where media_id in (1,2,9);
三、插入
SQLiteDatabase db=this.getWritableDatabase();
        ContentValues cv=new ContentValues();
        cv.put(FIELD_TITLE, Title);
        long row=db.insert(TABLE_NAME, null, cv);
四、更新
        String where=FIELD_ID+"=?";
        String[] whereValue={Integer.toString(id)};
        db.update(TABLE_NAME, cv, where, whereValue);
五、删除
        db.delete(TABLE_NAME, where, whereValue);
