阅读:2486回复:0
android截取屏幕图片
更多 发布于:2012-09-06 13:52
package com.iceman.printscreen;
import java.io.File;
import java.io.FileOutputStream;
import Android.app.Activity;
import Android.graphics.Bitmap;
import Android.graphics.Bitmap.Config;
import Android.os.Bundle;
import Android.os.Environment;
import Android.view.Display;
import Android.view.LayoutInflater;
import Android.view.View;
import Android.view.View.OnClickListener;
import Android.view.WindowManager;
import Android.widget.Button;
import Android.widget.LinearLayout;
import Android.widget.Toast;
public class PrintScreenDemoActivity extends Activity {
    private Button mButton;
    private LinearLayout mLayout;
    private int mPrintNum;
    @Override
        LayoutInflater inf = this.getLayoutInflater();
        mLayout = (LinearLayout)inf.inflate(R.layout.main, null);
        setContentView(mLayout);
        mButton = (Button)findViewById(R.id.print_btn);
        mButton.setOnClickListener(new OnClickListener() {
            public void onClick(View v) {
                GetandSaveCurrentImage();
                mPrintNum++;
                mButton.setText("截屏次数:"+mPrintNum);
    private void GetandSaveCurrentImage()
        //1.构建Bitmap
        WindowManager windowManager = getWindowManager();
        Display display = windowManager.getDefaultDisplay();
        int w = display.getWidth();
        int h = display.getHeight();
        Bitmap Bmp = Bitmap.createBitmap( w, h, Config.ARGB_8888 );
        //2.获取屏幕
        View decorview = this.getWindow().getDecorView();
        decorview.setDrawingCacheEnabled(true);
        Bmp = decorview.getDrawingCache();
        String SavePath = getSDCardPath()+"/PrintScreenDemo/ScreenImage";
        //3.保存Bitmap
        try {
            File path = new File(SavePath);
            //文件
            String filepath = SavePath + "/Screen_"+mPrintNum+".png";
            File file = new File(filepath);
            if(!path.exists()){
                path.mkdirs();
            if (!file.exists()) {
                file.createNewFile();
            FileOutputStream fos = null;
            fos = new FileOutputStream(file);
            if (null != fos) {
                Bmp.compress(Bitmap.CompressFormat.PNG, 90, fos);
                fos.flush();
                fos.close();
                Toast.makeText(this, "截屏文件已保存至SDCard/PrintScreenDemo/ScreenImage/下", Toast.LENGTH_LONG).show();
        } catch (Exception e) {
            e.printStackTrace();
        * 获取SDCard的目录路径功能
        * @return
    private String getSDCardPath(){
        File sdcardDir = null;
        //判断SDCard是否存在
        boolean sdcardExist = Environment.getExternalStorageState().equals(Android.os.Environment.MEDIA_MOUNTED);
        if(sdcardExist){
            sdcardDir = Environment.getExternalStorageDirectory();
        return sdcardDir.toString();
布局文件:
    <Button
        Android:id="@+id/print_btn"
        Android:text="截屏" />
</LinearLayout>
由于是把截屏的图片存放到sd卡里,所以要在manifest.xml文件中增加对sd卡的写入权限.
