阅读:3294回复:0
图片文件上传
更多 发布于:2012-09-06 13:52
[java]        //一些定义的变量
       private String newName = "image.jpg";
private String uploadFile = "/sdcard/apple.jpg";
//private String actionUrl = "http://localhost:8080/testCutPic/upload.php";
//上传图片地址,上传的图片文件参数名为fileToUpload
private String actionUrl="http://192.168.1.64/svn_ys/sousoutu/api/api_imgupload.php";
        //一些定义的变量
HttpClient请求客户端方式:
[html]               private void postFile(){
   HttpClient httpclient = new DefaultHttpClient();
   httpclient.getParams().setParameter(CoreProtocolPNames.PROTOCOL_VERSION, HttpVersion.HTTP_1_1);
    HttpPost httppost = new HttpPost("http://192.168.1.64/svn_ys/sousoutu/api/api_imgupload.php");
    File file = new File(uploadFile);
//  File file2=new File(uploadFile);
    ContentBody cbFile = new FileBody(file, "image/jpeg");
//  ContentBody cbFile2 = new FileBody(file2, "image/jpeg");
    MultipartEntity mpEntity = new MultipartEntity();
    mpEntity.addPart("fileToUpload", cbFile);
//  mpEntity.addPart("fileToUpload2", cbFile2);
       //  mpEntity.addPart("字符串参数", new StringBody("user"));
    httppost.setEntity(mpEntity);
    Log.d("log", "请求信息: " + httppost.getRequestLine());
//   System.out.println("executing request " + httppost.getRequestLine());
    HttpResponse response = null;
    try {
        response = httpclient.execute(httppost);
    } catch (ClientProtocolException e1) {
        // TODO Auto-generated catch block
        e1.printStackTrace();
    } catch (IOException e1) {
    HttpEntity resEntity = response.getEntity();
    Log.d("log", "响应信息:"+response.getStatusLine().toString());
   // System.out.println(response.getStatusLine());
    if (resEntity != null) {
      try {
          final String response_str=EntityUtils.toString(resEntity);
          Log.d("log", response_str);
    } catch (ParseException e) {
        e.printStackTrace();
    } catch (IOException e) {
      try {
        resEntity.consumeContent();
    httpclient.getConnectionManager().shutdown();
   try {
        try {
        try {
     }字节流的方式上传:
[html] private void uploadFile() {
String end = "\r\n";
String twoHyphens = "--";
String boundary = "*****";
try {
    URL url = new URL(actionUrl);
    HttpURLConnection con = (HttpURLConnection) url.openConnection();
    con.setDoInput(true);
    con.setDoOutput(true);
    con.setUseCaches(false);
    con.setRequestMethod("POST");
    con.setRequestProperty("Connection", "Keep-Alive");
    con.setRequestProperty("Charset", "UTF-8");
    con.setRequestProperty("Content-Type",
            "multipart/form-data;boundary=" + boundary);
    DataOutputStream ds = new DataOutputStream(con.getOutputStream());
    ds.writeBytes(twoHyphens + boundary + end);
    ds.writeBytes("Content-Disposition: form-data; "
            + "name=\"file1\";filename=\"" + newName + "\"" + end);
    ds.writeBytes(end);
    FileInputStream fStream = new FileInputStream(uploadFile);
    int bufferSize = 1024;
    byte[] buffer = new byte[bufferSize];
    int length = -1;
    while ((length = fStream.read(buffer)) != -1) {
        ds.write(buffer, 0, length);
    ds.writeBytes(end);
    ds.writeBytes(twoHyphens + boundary + twoHyphens + end);
    fStream.close();
    ds.flush();
    InputStream is = con.getInputStream();
    int ch;
    StringBuffer b = new StringBuffer();
    while ((ch = is.read()) != -1) {
        b.append((char) ch);
    showDialog("上传成功" + b.toString().trim());
    ds.close();
} catch (Exception e) {
    showDialog("上传失败" + e);
  try {
   ds.writeBytes(end);
   int length = -1;
   ds.writeBytes(end);
   fStream.close();
   ds.flush();
   int ch;
   ds.close();
用到的dialog对话框,用来显示测试结果:
[html]    private void showDialog(String mess) {
w AlertDialog.Builder(TestuploadImageActivity.this)
.setTitle("Message").setMessage(mess)
.setNegativeButton("确定", new Dialoginterface.OnClickListener() {
    public void onClick(DialogInterface dialog, int which) {
}).show();
