阅读:3303回复:0
Android 程式开发:(一)详解活动 —— 1.6 显示复杂对话框
更多 发布于:2012-09-06 14:03
除了“对话框”进度条,也可以创建一个显示“操作进度”的对话框,例如显示正在下载的状态。
1、创建一个工程:Dialog。
2、main.xml中的代码。
    <Button
        Android:id="@+id/btn_dialog3"
        Android:onClick="onClick3"
        Android:text="Click to display a detailed progress dialog" />
</LinearLayout>
3、DialogActivity.java中的代码。package net.horsttnann.Dialog;
import Android.app.Activity;
import Android.app.Dialog;
import Android.app.ProgressDialog;
import Android.content.Dialoginterface;
import Android.os.Bundle;
import Android.view.View;
import Android.widget.Toast;
public class DialogActivity extends Activity {
    ProgressDialog progressDialog;
    @Override
    public void onClick3(View v) {
        showDialog(1);
        progressDialog.setProgress(0);
        new Thread(new Runnable() {
            public void run() {
                for (int i = 1; i <= 15; i++) {
                    try {
                        // ---simulate doing something lengthy---
                        Thread.sleep(1000);
                        // ---update the dialog---
                        progressDialog.incrementProgressBy((int) (100 / 15));
                    } catch (InterruptedException e) {
                        e.printStackTrace();
                progressDialog.dismiss();
        }).start();
www.atcpu.com
    @Override
    protected Dialog onCreateDialog(int id) {
        switch (id) {
        case 1:
            progressDialog = new ProgressDialog(this);
            progressDialog.setIcon(R.drawable.ic_launcher);
            progressDialog.setTitle("Downloading files...");
            progressDialog.setProgressStyle(ProgressDialog.STYLE_HORIZONTAL);
            progressDialog.setButton(DialogInterface.BUTTON_POSITIVE, "OK",
                    new DialogInterface.OnClickListener() {
                        public void onClick(DialogInterface dialog,
                                int whichButton) {
                            Toast.makeText(getBaseContext(), "OK clicked!",
                                    Toast.LENGTH_SHORT).show();
            progressDialog.setButton(DialogInterface.BUTTON_NEGATIVE, "Cancel",
                                int whichButton) {
                            Toast.makeText(getBaseContext(), "Cancel clicked!",
            return progressDialog;
        return null;
4、按F11调试。
想要创建一个显示进度的对话框,首先要创建一个ProgressDialog类的实例,然后设置各种状态,图标、标题、样式等等:
然后设置两个按钮:progressDialog.setButton(DialogInterface.BUTTON_POSITIVE, "OK",
                    int whichButton) {
                    int whichButton) {
使用一个线程显示进度条的状态:progressDialog.setProgress(0);
    public void run() {
            try {
                Thread.sleep(1000);
}).start();
当进度条到达100%的时候,它就被解除了。
作者 manoel的专栏
