阅读:3881回复:0
android三种载入图片方式
更多 发布于:2012-09-06 14:06
[java]
package smalt.music.utils;
import Android.graphics.Bitmap;
import Android.graphics.BitmapFactory;
import Android.graphics.BitmapFactory.Options;
//加载图片的方法:3种
public class BitmapUntil {
    // 直接載入圖片
    public static Bitmap getBitmap(String path) {
        Bitmap bt = BitmapFactory.decodeFile(path);
        return bt;
    // 指定大小載入圖片
    public static Bitmap getBitmap(String path, int size) {
        Options op = new Options();
        op.inSampleSize = size;
        Bitmap bt = BitmapFactory.decodeFile(path, op);
        return bt;  www.atcpu.com
    // 按寬高壓縮載入圖片
    public static Bitmap getBitmap(String path, int width, int heigh) {
        op.inJustDecodeBounds = true;
        int xScale = op.outWidth / width;
        int yScale = op.outHeight / heigh;
        op.inSampleSize = xScale > yScale ? xScale : yScale;
        op.inJustDecodeBounds = false;
        return bt;
作者:yhm2046
