阅读:2932回复:0
IBatis.Net学习笔记(一)--两种常用的DAO
更多 发布于:2012-09-08 09:38
在IBatis中我们可以灵活的选择DAO类型,也就是可以在底层选用不同的数据库操作方式。有常规方式、配置文件的方式、Hibernet的方式等:
1、常规方式
和我们之前的ADO.NET开发较为类似,都是将sql语句写在cs代码中进行调用:
首先通过配置文件初始化:
            DomDaoManagerBuilder builder = new DomDaoManagerBuilder();
            builder.Configure("dao" + "_" + ConfigurationManager.AppSettings["database"] + "_"
                + ConfigurationManager.AppSettings["providerType"] + ".config");
            daoManager = DaoManager.GetInstance("SimpleDao");
相对应的配置文件如下:
    <context id="SimpleDao" default="true">
        <properties resource="http://www.cnblogs.com/database.config"/>
        <!-- ==== SqlClient configuration (default provider) =========    -->
        <database>
            <!-- Optional ( default ) -->
            <provider name="sqlServer1.1"/>
            <dataSource name="iBatisNet" connectionString="data source=${datasource};database=${database};user id=${userid};password=${password};connection reset=false;connection lifetime=5; min pool size=1; max pool size=50"/>
        </database>
        <daoFactory>
            <dao interface="IBatisNet.DataAccess.Test.Dao.Interfaces.IAccountDao, IBatisNet.DataAccess.Test" implementation="IBatisNet.DataAccess.Test.Dao.Implementations.Ado.AccountDao, IBatisNet.DataAccess.Test"/>
        </daoFactory>
    </context>
然后在对应的,比如AccountDao中写具体的查询sql等
2、配置方式
将sql语句放在配置文件中,书写和修改较灵活,这也是比较常用的方式
首先通过配置文件初始化:
            daoManager = DaoManager.GetInstance("SqlMapDao");
相对应的配置文件如下:
    <context id="SqlMapDao">
        <!-- ==== SqlClient configuration =========    -->
        <database>
        </database>
        <daoSessionHandler id="SqlMap">
            <property name="resource" value="SqlMap_MSSQL_SqlClient.config"/>
            <!-- <property name="url" value="E:\Projet\iBatis\trunk\cs\mapper\IBatisNet.DataAccess.Test\bin\Debug\SqlMap_MSSQL_SqlClient.config"/>
            <property name="embedded" value="bin.Debug.SqlMap_MSSQL_SqlClient.config, IBatisNet.DataAccess.Test"/>
        </daoSessionHandler>
        <daoFactory>
            <dao interface="IBatisNet.DataAccess.Test.Dao.Interfaces.IAccountDao, IBatisNet.DataAccess.Test" implementation="IBatisNet.DataAccess.Test.Dao.Implementations.DataMapper.AccountDao, IBatisNet.DataAccess.Test"/>
        </daoFactory>
    </context>
然后可以将每一张表的sql语句单独放在一个配置文件中,比如:
        <select id="GetAccountsDynamic" resultMap="account-result" parameterClass="Hashtable" >
            select top $MaximumAllowed$ * from Accounts
            <dynamic prepend="where">
                    <isParameterPresent>
                    <isNotEmpty prepend="and" property="FirstName" >
                            Account_FirstName LIKE '%$FirstName$%'
                    </isNotEmpty>
                    <isNotEmpty prepend="and" property="LastName" >
                            Account_LastName LIKE '%$LastName$%'
                    </isNotEmpty>
                    <isNotEmpty prepend="and" property="EmailAddress"  >
                            Account_Email LIKE '%$EmailAddress$%'
                    </isNotEmpty>
                    </isParameterPresent>
                </dynamic>
                order by Account_LastName
        </select>
3、使用Hibernet方式
也就是使用Hibernet的数据库操作。
