阅读:3221回复:0
使用PHP实现GET,POST数据
更多 发布于:2012-09-12 06:50
1. 使用 php 获得网页内容 GET方式
<?php
function socketGet($url, ;$ret)
$urlArr = parse_url($url);
$host = $urlArr['host'];
$port = isset($urlArr['port'])?$urlArr['port']:80;
$path = isset($urlArr['path'])?$urlArr['path']:"/";
$fp = fsockopen($host, $port, $errno, $errstr, 30);
if (!$fp)
  echo "$errstr ($errno)<br />\n";
  return false;
else
     $out = "GET $path HTTP/1.1\r\n";
     $out .= "Host: $host\r\n";
     $out .= "Connection: Close\r\n\r\n";
  $ret = "";
     fwrite($fp, $out);
     while (!feof($fp))
         $ret .= fgets($fp, 128);
     fclose($fp);
return true;
2. 使用 php 向页面 POST 数据
<?php
function socketPost($url, $data, ;$ret)
if (!$fp)
  return false;
else
     $out = "POST $path HTTP/1.1\r\n";
  $out .= "Content-Type: application/x-www-form-urlencoded\r\n";
  $out .= "Content-Length: ".strlen($data)."\r\n";
     $out .= "Connection: Keep-Alive\r\n\r\n";
  $out .= $data;
  $ret = "";
     fwrite($fp, $out);
     while (!feof($fp))
     fclose($fp);
return true;
如果post报错,把$out .= "Connection: Keep-Alive\r\n\r\n";中的Keep-Alive改成Close
摘自  与时俱进
