阅读:3402回复:0
教你在win8右键菜单添加关机,重启,注销
更多 发布于:2012-09-25 15:38
在Windows 8右键菜单添加关机,重启,注销,休眠,睡眠,切换用户,锁住。呃呃呃想不到Windows 8的关机把大家给难住了 ……
  Windows 8右键菜单添加关机,重启,注销…
  原理就是在注册表中添加命令,新建立记事本,把以下内容保存为.reg,双击导入即可。
  Windows Registry Editor Version 5.00
  [HKEY_CLASSES_ROOTDesktopBackgroundShellPower Menu]
  “MUIVerb”=”Power Menu”
  “SubCommands”=”lock;logoff;switch;sleep;hibernate;restart;shutdown”
  “Icon”=”shell32.dll,215″
  “Position”=”bottom”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshelllock]
  @=”Lock”
CommandStoreshelllockcommand]
  @=”Rundll32 User32.dll,LockWorkStation”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshelllogoff]
  @=”Log Off”
CommandStoreshelllogoffcommand]
  @=”Shutdown -l”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshellswitch]
  @=”Switch User”
CommandStoreshellswitchcommand]
  @=”tsdiscon.exe”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshellsleep]
  @=”Sleep”
rCommandStoreshellsleepcommand]
  @=”rundll32.exe powrprof.dll,SetSuspendState Sleep”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshellhibernate]
  @=”Hibernate”
CommandStoreshellhibernatecommand]
  @=”Shutdown -h”
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshellrestart]
  @=”Restart”
CommandStoreshellrestartcommand]
  @=”Shutdown -r -f -t 00″
  [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerCommandStoreshellshutdown]
  @=”Shut Down”
rCommandStoreshellshutdowncommand]
  @=”Shutdown -s -f -t 00″
  当然你也可以下载现成的注册表文件,包含卸载
