阅读:5021回复:0
android ScrollVIew中嵌套GridView,如何显示GridView
更多 发布于:2012-10-22 13:53
在Android开发当中经常会用到了需要ScrollView嵌套GridView或者是ListView的情况,由于这两款控件都自带滚动条,当他们一起使用的时候就会出现GridView或ListView会显示不全的问题。
自定义MyGridView
public class MyGridView extends GridView {
   public MyGridView(Context context) {
        super(context);
   public MyGridView(Context context, AttributeSet attrs) {
        super(context, attrs);
    public MyGridView(Context context, AttributeSet attrs, int defStyle) {
        super(context, attrs, defStyle);
    @Override
    public void onMeasure(int widthMeasureSpec, int heightMeasureSpec) {
        int expandSpec = MeasureSpec.makeMeasureSpec(Integer.MAX_VALUE >> 2,
                MeasureSpec.AT_MOST);
        super.onMeasure(widthMeasureSpec, expandSpec);
xml中的布局文件:
<com.xxx.MyGridView
             android:id="@+id/mygridview"
             android:layout_width="fill_parent"
             android:layout_height="wrap_content"
             android:gravity="center"
             android:horizontalSpacing="5dp"
             android:numColumns="4"
             android:stretchMode="columnWidth"
             android:verticalSpacing="6dp" />
java调用代码
MyGridView gridview = (MyGridView) findViewById(R.id.mygridview);
gridview.setAdapter(new XxxAdapter(xxx));
