593249217
总版主
总版主
  • 注册日期2010-11-25
  • 发帖数385
  • QQ593249217
  • 火币969枚
  • 粉丝282
  • 关注1
  • 幽默大师奖
阅读:6031回复:0
一段扫flash跨站的脚本
更多 发布于:2010-11-26 17:34
主要是扫Externalinterface.call
<?php
/*--------------------------------123322----------------------------
#Flash文件跨站检测脚本 2010/6/3
#检测过程如下:
提取ExternalInterface.call调用的参数,检查参数是都是直接通过loaderInfo.parameters获取
#使用方法
./scan.php /as代码目录>log
----------------------------------123322---------------------------*/
set_time_limit(0);
function find($directory)
$mydir=dir($directory);
while($file=$mydir->read()){
if((is_dir("$directory/$file"));;($file!=".");;($file!=".."))
find("$directory/$file");
else{
if($file != "." ;; $file != "..";;eregi(".as",$file)){
$fd=realpath($directory."/".$file);
$fp = fopen($fd, "r");
$i=0;
while ($buffer = fgets($fp, 128)) {
$i++;
if(eregi("ExternalInterface.call",$buffer))
echo "Line".$i.":".$buffer."\r\n\r\n";
preg_match("/\((.*)\)/i", $buffer, $match);
if (strstr($match[1],"("))
preg_match("/\((.*)\)/i", $match[1], $newmatch);
echo "再次提取后参数包含 :".$newmatch[1]."\r\n\r\n";
$oldfp = ftell($fp);
fseek($fp, 0);
$p = 0;
while ($newbuffer = fgets($fp, 128))
$p++;
if(eregi("loaderInfo.parameters",$newbuffer))
//echo "Line".$p.":".$newbuffer."\r\n";
if (strstr($newbuffer,$newmatch[1]))
echo $newmatch[1]."存在漏洞\r\n\r\n";
fseek($fp, $oldfp);
unset($oldfp);
} elseif(strstr($match[1],","))
echo "多个参数:$match[1]\r\n";
if (strstr($match[1],"loaderInfo.parameters")){
echo $match[1]."直接调用loaderInfo.parameters传递存在漏洞\r\n\r\n";
$var_array = array();
$var_array = explode(",",$match[1]);
fseek($fp,0);
//echo "Line".$p.":".$newbuffer."\r\n\r\n";
foreach ($var_array as $value)
if (strstr($newbuffer,$value))
echo trim($value)."存在漏洞\r\n\r\n";
fseek($fp, $oldfp);
unset($oldfp);
}else
echo "唯一参数:".$match[1]."\r\n";
fseek($fp,0);
if (strstr($newbuffer,$match[1]))
echo trim($match[1])."存在漏洞\r\n\r\n";
fseek($fp, $oldfp);
unset($oldfp);
fclose($fp);
$mydir->close();
function all()
static $count = 1;
echo $count;
$count++;
find($argv[1]);
多一分钟时间学习,就多一份技术!
