阅读:2040回复:0
Linux远程文件拷贝
更多 发布于:2012-12-20 16:00
Linux远程文件拷贝
Shell代码
#!/bin/sh
######把10.0.64.224主机上/data/sea/upload/底下文件拷贝到10.10.31.79#############
######文件拷贝成功后,把文件从10.0.64.224主机上删除,本地记录操作日志#############
#远程主机地址
remote_ip=10.0.64.224;
#远程主机登录用户
remote_user=root;
#远程主机目录
remote_path="/data/sea/upload";
#本地保存远程拷贝文件目录
local_path="/usr/data/upload/ftpupload";
#本地日志文件输出目录
log_dir="/home/web_sea/logs";
log_file_date=`date +%F`;
for file in `ssh ${remote_ip} ls ${remote_path}`
do
     scpfile="scp ${remote_user}@${remote_ip}:${remote_path}/${file} ${local_path}/";
     $scpfile;
     log_date=`date +%F" "%T`;
     if [ $? -eq 0 ] ; then
        echo "$log_date debug scp file [$file] is successfully" >> $log_dir/access_${log_file_date}.log
        ssh ${remote_ip} rm -rf ${remote_path}/${file}
            echo "$log_date debug delete file [$file] is successfully" >> $log_dir/access_${log_file_date}.log
        else
            echo "$log_date error delete file [$file] is failure" >> $log_dir/error_${log_file_date}.log
        fi
     else
        echo "$log_date error scp file [$file] is failure" >> $log_dir/error_${log_file_date}.log
     fi
done
