111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:4593回复:0
从数据库导出数据到word、excel、.txt _asp.net技巧
更多 发布于:2010-12-15 21:01
using System;
using System.Data;
using System.Drawing;
using System.Data.SqlClient;
using Excel;
using Word;
using System.IO;
namespace Common
 /// 把数据导入到.doc、.txt、.xls文件中
 public class Export
  private const string DATAWORDPATH = @"C:\folder\doc\datadoc\";
  private const string IMAGEWORDPATH = @"C:\folder\doc\imagedoc\";
  private const string IMAGEPATH = @"C:\folder\image\";
  private const string EXCELPATH = @"C:\folder\excel\";
  private const string TXTPATH = @"C:\folder\txt\";
  private const string IMAGEPOSTFIX = ".bmp";
  private const string WORDPOSTFIX = ".doc";
  private const string EXCELPOSTFIX = ".xls";
  private const string TXTPOSTFIX = ".txt";
  private const int DATADISTANCE = 5;
  private const int TABDISTANCE = 8;
  public Export()
   // TODO: 在此处添加构造函数逻辑
  /// 获得数据集Dataset--------------------------------用于调试
  /// Dataset
  public DataSet GetData()
   try
    string sConnectionString;
    sConnectionString = "workstation id=GUOFU;packet size=4096;user id=sa;data source=GUOFU;persist security info=True;initial catalog=YC;password=sc";
    SqlConnection objConn = new SqlConnection(sConnectionString);
    objConn.Open();
    SqlDataAdapter daPoint = new SqlDataAdapter("Select * From Point", objConn);
    DataSet dsYC = new DataSet("YC");
    daPoint.FillSchema(dsYC,SchemaType.Mapped, "Point");
    daPoint.Fill(dsYC,"Point");
    daPoint = new SqlDataAdapter("Select * From Employee", objConn);
    daPoint.FillSchema(dsYC,SchemaType.Mapped, "Employee");
    daPoint.Fill(dsYC,"Employee");
    return dsYC;
   catch(Exception ex)
    throw new Exception(ex.Message);
  /// 把数据文件导入到.xls文件
  public void ExportToExcel(DataSet ds)
  if(ds.Tables.Count!=0)
    //生成.xls文件完整路径名
    string tempFileName = GetTempFileName();
    object filename = EXCELPATH+tempFileName+EXCELPOSTFIX;
    object Nothing = System.Reflection.Missing.Value;
    //创建excel文件,文件名用系统时间生成精确到毫秒
    Excel.Application myExcel = new Excel.ApplicationClass();
    myExcel.Application.Workbooks.Add(Nothing);
   try
     //把Dataset中的数据插入excel文件中
     int totalCount = 0;
     for(int k =0;k      for(int i = 0;i     try
      //保存excel文件到指定的目录下,文件名用系统时间生成精确到毫秒
      myExcel.ActiveWorkbook._SaveAs(filename,Nothing,Nothing,Nothing,Nothing,Nothing,XlSaveAsAccessMode.xlExclusive,Nothing,Nothing,Nothing,Nothing);
     catch
      System.视窗系统.Forms.MessageBox.Show("系统未找到指定目录下的文件:  "+EXCELPATH+tempFileName+EXCELPOSTFIX);
      return;
     //让生成的excel文件可见
     myExcel.Visible = true;
    catch(Exception e)
     System.视窗系统.Forms.MessageBox.Show("向excel文件中写入数据出错:  " + e.Message);
   else
    System.视窗系统.Forms.MessageBox.Show("No Data");
  /// 把数据导入到.doc文件
  public void ExportToWord(DataSet ds)
    string tempFileName = null;
    object filename = null;
    object tableBehavior = Word.WdDefaultTableBehavior.wdWord9TableBehavior;
    object autoFitBehavior = Word.WdAutoFitBehavior.wdAutoFitFixed;
   object unit = Word.WdUnits.wdStory;
    object extend = System.Reflection.Missing.Value;
    object breakType = (int)Word.WdBreakType.wdSectionBreakNextPage;
   object count = 1;
    object character = Word.WdUnits.wdCharacter;
    try
    //生成.doc文件完整路径名
     filename = DATAWORDPATH+tempFileName+WORDPOSTFIX;
     //创建一个word文件,文件名用系统时间生成精确到毫秒
     Word.Application myWord= new Word.ApplicationClass();
     Word._Document myDoc = new Word.DocumentClass();
     myDoc = myWord.Documents.Add(ref Nothing,ref Nothing,ref Nothing,ref Nothing);
     myDoc.Activate();
    //向把dataset中的表插入到word的文件中
     for(int totalTable = 0;totalTable
  /// 把图片文件导入到.doc文件
  public void ExportToWord(Bitmap bp)
   string bmpPath = null;
   object Nothing = null;
   //生成.bmp文件完整路径名
   bmpPath = IMAGEPATH+tempFileName+IMAGEPOSTFIX;
  //生成.doc文件完整路径名
   filename = IMAGEWORDPATH+tempFileName+WORDPOSTFIX;
  try
    //把bitmap对象保存到系统所生成文件完整路径中
    bp.Save(bmpPath);
   catch
    System.视窗系统.Forms.MessageBox.Show("系统未找到指定目录下的文件:  "+bmpPath);
    return;
   try
    //往word文件中插入图片
    myDoc.InlineShapes.AddPicture(bmpPath,ref Nothing,ref Nothing,ref Nothing);
   catch
    return;
   try
    //保存word文件到指定的目录下
    myDoc.SaveAs(ref filename,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing,ref Nothing);
   catch
    System.视窗系统.Forms.MessageBox.Show("系统未找到指定目录下的文件:  "+IMAGEWORDPATH+tempFileName+WORDPOSTFIX);
    return;
  //让生成的word文件可见
   myWord.Visible = true;
  /// 把数据文件导入到.txt文件
  public void ExportToTxt(DataSet ds)
    //创建一个.txt文件,文件名用系统时间生成精确到毫秒
    FileInfo file = new FileInfo(TXTPATH+tempFileName+TXTPOSTFIX);
    StreamWriter textFile = null;
    try
     textFile = file.CreateText();
    catch
     System.视窗系统.Forms.MessageBox.Show("系统未找到指定目录下的文件:  "+TXTPATH+tempFileName+TXTPOSTFIX);
     return;
   //把Dataset中的数据写入.txt文件中
    for(int totaltable = 0;totaltable
