阅读:10278回复:0
我的学习生涯(Delphi篇) - 01
更多 发布于:2013-05-13 10:06
 Delphi中包装了几乎所有的WIN32 API。
   这些API至今还活跃在Windows平台!
   比如下文出现的 BlockRead/ BlockWrite就是调用IOPro函数。
   效果如下图:
Unit1.pas
[delphi]
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, ShellApi, StdCtrls;
type
  TForm1 = class(TForm)
    Button1: TButton;
    Button2: TButton;
    Button3: TButton;
    Edit1: TEdit;
    Edit2: TEdit;
    Label1: TLabel;
    Label2: TLabel;
    procedure Button1Click(Sender: TObject);
    procedure Button2Click(Sender: TObject);
    procedure Button3Click(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
  end;
var
  Form1: TForm1;
  procedure mycopyfile(Sfname,Dfname:string);
implementation
{$R *.dfm}
procedure TForm1.Button1Click(Sender: TObject);
var
  lphKey: HKEY;
  sKeyName: string;
  sKeyValue: string;
begin
    sKeyName := 'myfile';
    sKeyValue :='我的文档';
    RegCreateKey(HKEY_CLASSES_ROOT,pchar(sKeyName),lphKey);
    RegSetValue(lphKey,'',REG_SZ,pchar(sKeyValue),0);
    sKeyName := '.xbf';
    sKeyValue := 'myfile';
    sKeyValue := 'e:\WINNT\SYSTEM32\NotePad.exe "%1"';
    RegSetValue(lphKey,'shell\open\command',REG_SZ,pchar(sKeyValue),MAX_PATH);
end;
procedure TForm1.Button2Click(Sender: TObject);
begin
  //ShellExecute(Application.Handle,'open','NotePad.exe','',nil,SW_SHOWNORMAL);
  //WinExec('command.com',SW_SHOWNORMAL);
end;
Var
  Sourcef,Destinef:file;
  NumRead,NumWritten:Integer;
  Buf:array[1..4096] of char;//定义缓冲区;
Begin
  //Dfname:='c:\xiaobin.xbf';
  AssignFile(Sourcef,Sfname);
  Reset(Sourcef,1);
  AssignFile(Destinef,Dfname);
  Rewrite(Destinef,1);
  Repeat
    BlockRead(Sourcef,Buf,SizeOf(Buf),Numread);//读源文件
    BlockWrite(destinef,buf,NumRead,NumWritten);//写目标文件;
  Until (Numread=0) or (Numwritten<>numread);
    //BlockRead(Sourcef,buf,SIZEOF(buf),NumRead);
    //BlockWrite(Destinef,buf,NumRead,NumWritten);
    closeFile(Sourcef);
    Closefile(destinef);
end;
procedure TForm1.Button3Click(Sender: TObject);
begin
  if  FileExists(Edit2.Text) then
  begin
    if Application.MessageBox('文件已经存在!是否覆盖?','提示',MB_YESNO)=IDYES then
    begin
      mycopyfile(Edit1.Text,Edit2.Text);
      //CopyFile('c:\xiaobin.xbf','d:\xiaobin.xbf',True);
      Application.MessageBox('文件复制完成!','消息',32);
    end;
  end
  else
  begin
  end;
end;
end.
unit Unit1;
interface
uses
type
    Button1: TButton;
    Button2: TButton;
    Button3: TButton;
    Edit1: TEdit;
    Edit2: TEdit;
    Label1: TLabel;
    Label2: TLabel;
  private
  public
  end;
var
  Form1: TForm1;
implementation
{$R *.dfm}
var
  lphKey: HKEY;
  sKeyName: string;
  sKeyValue: string;
begin
    sKeyValue :='我的文档';
    sKeyName := '.xbf';
end;
begin
end;
Var
Begin
  Reset(Sourcef,1);
  Repeat
    closeFile(Sourcef);
end;
begin
  begin
    begin
    end;
  end
  else
  begin
  end;
end;
end.
