阅读:1886回复:0
ARP本机绑定的bat代码
更多 发布于:2013-05-28 10:33
通过ipconfig获取ip与mac地址,并通过arp绑定,主要是需要掌握for命令的使用
复制代码 代码如下:
@echo off
if exist ipconfig.txt del ipconfig.txt
ipconfig /all >ipconfig.txt
if exist phyaddr.txt del phyaddr.txt
find "Physical Address" ipconfig.txt >phyaddr.txt
for /f "skip=2 tokens=12" %%M in (phyaddr.txt) do set Mac=%%M
if exist IPAddr.txt del IPaddr.txt
find "IP Address" ipconfig.txt >IPAddr.txt
for /f "skip=2 tokens=15" %%I in (IPAddr.txt) do set IP=%%I
arp -s %IP% %Mac%
del ipaddr.txt
del ipconfig.txt
del phyaddr.txt
exit
