阅读:2036回复:0
批处理实现的网络巡检脚本(PING与端口扫描)
更多 发布于:2013-05-29 10:51
为了假期检查方便,写了个巡检脚本,可在脚本的report段添加一些报告机制,然后添加到计划任务作自动检查。没作太多描述,写过脚本的应该都懂的。portqry 可以到微软网站下载。 自动化的性能监控和报警,推荐SCOM
check.bat 内容(脚本内容可能会应为排版问题不能直接复制粘帖运行,可自行修改):
复制代码 代码如下:
@echo off
rem checklist.csv字段为: IP,名称,描述,TCP应用端口,UDP应用端口
rem checklist.csv中请使用,@,替换,, 并不要使用()进行内容描述
set e_file=error.log
set e_count=0
for /f "skip=1 tokens=1,2,3,4,5* delims=," %%i in (checklist.csv) do call :docheck %%i @%%j @%%k @%%l @%%m
call :report
goto :eof
:docheck
set ip=%1
set name=%2
set name=%name:@=%
set comment=%3
set comment=%comment:@=%
set tcp=%4
set tcp=%tcp:@=%
set udp=%5
set udp=%udp:@=%
ping %ip% -n 3 -w 300 >nul 2>&1
if NOT %ERRORLEVEL%==0 (echo %time% %ip%[%name%,%comment%] ping error >>%e_file% & set /a e_count=%e_count%+1) else call :portcheck
call :report
goto :eof
:portcheck
if not -%tcp%==- for /f "tokens=1,2,3,4,5,6,7,8,9,10* delims=-" %%i in ("%tcp%") do call :tcpcheck %%i %%j %%k %%l %%m %%n %%o %%p %%q
if not -%udp%==- for /f "tokens=1,2,3,4,5,6,7,8,9,10* delims=-" %%i in ("%udp%") do call :udpcheck %%i %%j %%k %%l %%m %%n %%o %%p %%q
goto :eof
:tcpcheck
if not -%1==- call :tcpquery %1
if not -%2==- call :tcpquery %2
if not -%3==- call :tcpquery %3
if not -%4==- call :tcpquery %4
if not -%5==- call :tcpquery %5
if not -%6==- call :tcpquery %6
if not -%7==- call :tcpquery %7
if not -%8==- call :tcpquery %8
if not -%9==- call :tcpquery %9
goto :eof
:udpcheck
if not -%1==- call :udpquery %1
if not -%2==- call :udpquery %2
if not -%3==- call :udpquery %3
if not -%4==- call :udpquery %4
if not -%5==- call :udpquery %5
if not -%6==- call :udpquery %6
if not -%7==- call :udpquery %7
if not -%8==- call :udpquery %8
if not -%9==- call :udpquery %9
goto :eof
:tcpquery
portqry -n %ip% -e %1 -p tcp || (echo %time% %ip%[%name%,%comment%] tcp port %1 query error >>%e_file% & set /a e_count=%e_count%+1)
goto :eof
:udpquery
portqry -n %ip% -e %1 -p udp || (echo %time% %ip%[%name%,%comment%] udp port %1 query error >>%e_file% & set /a e_count=%e_count%+1)
goto :eof
:report
echo %e_count%
rem do whatever you want. such as send error.log by mail
goto :eof
checklist.csv样例:
IP,名称,描述,TCP应用端口,UDP应用端口 '两个逗号之间要加入@,描述不能加入括号(),请用[]替代
192.168.0.1,@,@,@,
192.168.0.3,@,@,@,
192.168.0.9,FTPSERVER,FTP服务器,135-445-21,
192.168.0.10,TESTSERVER,TESTSERVER,135-445-21,53
