阅读:2874回复:0
文本最末列数值乘一个数的批处理实现
更多 发布于:2013-06-02 16:48
只是对最末列的数值进行运算操作,其他不变。
a.txt
1##4072.0###52.19### #72## #
2#38705.8# # # 51.73## #70# #
372###389.0##51.80##19.77# # 72#####
4##59.71#3715.45##71######
以#和空格作为分隔符,最后一列的数值乘以7,其他不变。
已知的条件,数字是随机的,最末列的数值是整数,即使乘以7,仍在CMD所能计算范围内。
#与空格与“.”的位置和数量与每行的列数都是随机的。
输出如下:
1##4072.0###52.19### #504## #
2#38705.8# # # 51.73## #490# #
372###389.0##51.80##19.77# # 504#####
4##59.71#3715.45##497######
要求通用,高效。
ieutk:
复制代码 代码如下:
@echo off&setlocal enabledelayedexpansion
for /f "usebackq skip=35 delims=" %%a in ("%~dpnx0") do (
set "var=%%a"
set "e="
set "m=0"
set /a num+=1
call :is "%%a"
for /l %%a in (1 1 %num%) do echo.!_str1%%a!!_num%%a!!_str2%%a!
pause
goto :eof
:is
set "str=%~1"
if "%var:~-1%" lss "0" (
set "e=%var:~-1%!e!"
set "var=%var:~0,-1%"&set /a m+=1
goto is
set "_str2%num%=%e%
set "_strn%num%=!str:~0,-%m%!"
call :su "!_strn%num%!"
goto :eof
:su
set "a="
set "u=%~1"
set "y=0"
:st
for /l %%a in (0 1 9) do if "%u:~-1%"=="%%a" set "a=%u:~-1%!a!"&set /a y+=1
set "u=%u:~0,-1%"
for /l %%a in (0 1 9) do if "%u:~-1%"=="%%a" goto :st
set /a x+=1
set "_num%x%=%a%"
set /a _num%num%*=7
set "_str1%x%=!_strn%x%:~0,-%y%!"
goto :eof
5##4072.0###52.19### #72## #
6#38705.8# # # 51.73## #70# #
772###389.0##51.80##19.77# # 72#####
8##59.71#3715.45##71######
terse:
复制代码 代码如下:
for /l %%i in (0 1 9) do set %%i=%%i
for /f "delims=" %%i in (1.txt) do set "str=%%i"&call:lp
pause&goto :eof
:lp
set/a n+=1
set var=!str:~-%n%,1!
if defined !var! (set str2=!var!!str2!&set lp=lp) else (
if not defined lp (set str1=!var!!str1!) else (
set/a str2*=7&set str=!str:~,-%n%!!var!!str2!!str1!
>>b.txt echo !str!
for %%i in (str1 str2 n lp) do set %%i=
goto :eof
goto lp
youxi01:
复制代码 代码如下:
@echo off 2>nul 3>nul
for /f "delims=" %%a in (list.txt) do (
set /a n=0
set var=%%a
set var=!var:#= !
for %%i in (!var!) do set res=%%i
Rem '/*处理浮点///
set /a ok=!res! && (set /a res=!res!*7) || (set var=!res:*.=!
for /l %%i in (0 1 9) do set var=!var:%%i= %%i!
for %%i in (!var!) do set/a n+=1
set res=!res:.=!
set /a res=!res!*7
call set res=%%res:~0,-!n!%%.%%res:~-!n!%%)
echo !res!
pause>nul
huahua0919:
方法一:(用时0.25~0.30秒)
复制代码 代码如下:
for /f "delims=" %%i in (LastNumberChange.txt) do set/a n+=1&set LastLine=$%%i$
for /f "delims=" %%i in (LastNumberChange.txt) do (
set/a m+=1
if %n% neq !m! call set "all=!all!%%i&echo."
:start
set FirstNumber=%LastLine:~,1%
set "all1=!all1!%FirstNumber%"
set LastLine=%LastLine:~1%
echo %LastLine%|findstr "[0-9]" >nul&&goto :start
:all1
set /a t+=1
call set LastOne=%%all1:~-!t!%%
set/a x=LastOne*1
if "%LastOne%"=="%x%" goto :all1
set/a LastOne=%LastOne:~1%*7
set /a t-=1
set xlm=!all1:~,-%t%!
Set "Sum=%all%%xlm%%LastOne%%LastLine%"
echo %Sum:$=%
pause
方法二:(用时0.02~0.05秒)
复制代码 代码如下:
set/a m+=1
:LastOne
set/a x+=1
call set LastOne=%%LastLine:~-!x!,1%%
set /a Mult=%LastOne%*1
if not "%Mult%"=="%LastOne%" goto :LastOne
set/a x-=1
call set Front=%%LastLine:~,-%x%%%
call set Last=%%LastLine:~-%x%%%
:Middle
set/a x1+=1
call set LastOne1=%%Front:~-!x1!%%
set /a Mult1=%LastOne1%*1
if "%Mult1%"=="%LastOne1%" goto :Middle
set/a Middle=%LastOne1:~1%*7
set/a x1-=1
call set Front=%%Front:~,-%x1%%%
set "Sum=%all%%Front%%Middle%%Last%"
echo %Sum:$=%
pause
batman:
复制代码 代码如下:
@echo off
for /f "delims=" %%i in (1.txt) do (
set "str=%%i"&set "begin=a"
call :lp
echo !str!!a!!var!!last!
  endlocal
pause>nul&goto :eof
:lp
set "a=%str:~-1%"&set "str=%str:~,-1%"
if "%a%" geq "0" (
if "%a%" leq "9" set "flag=a"&set "begin="
if defined flag (
set var=%a%!var!&set "flag="
) else (
if defined begin (
set last=%a%!last!
) else (
  set /a var*=7&goto :eof
goto lp
随风:
复制代码 代码如下:
@echo off&setlocal EnableDelayedExpansion
for /l %%a in (0 1 9) do set .%%a=%%a
for /f "delims=" %%a in (a.txt) do (
set flag=&set num=&set sun=&set "str=%%a"
call :loop
pause
:loop
set "var=!str:~-1!"
if defined .!var! (set num=!var!!num!&set flag=a) else (set sun=!var!!sun!&set flag=)
if not defined num set str=!str:~0,-1!&goto loop
if defined flag set str=!str:~0,-1!&goto loop
set /a num*=7
echo !str!!num!!sun:~1!
goto:eof
