阅读:2890回复:0
查找偶数行内容的批处理
更多 发布于:2013-06-05 11:00
@echo off
:: 查找偶数行内容
set n=0
for /f "delims=" %%i in (test.txt) do set /a n+=1
for /l %%i in (1,2,%n%) do (
findstr /n "." test.txt|findstr /r "^%%i:">>tmp.txt
for /f "tokens=1* delims=:" %%i in (tmp.txt) do echo %%j>>end.txt
del tmp.txt
start end.txt
goto :eof
另一种方案
:: 不产生临时文件,并且速度要快得多
:: findstr中如果用.*,则在空行的位置会显示"ECHO 处于关闭状态。";
:: 如果用.,则不会打印空行
:: code by jm CMD@XP 2006-7-29
@echo off
cd.>result.txt
setlocal enabledelayedexpansion
for /f "tokens=1* delims=:" %%i in ('findstr /n "." test.txt') do (
set num=%%i
call :mod
if !mod! equ 0 echo %%j>>result.txt
start result.txt
goto :eof
:mod
set /a mod=%num%%%2
goto :eof
把上一段代码稍加改造,就可以去掉文本中的空行
@echo off
cd.>tmp.txt
for /f "tokens=1* delims=:" %%i in ('findstr /n "." test.txt') do (echo %%j>>tmp.txt)
cd.>result.txt
:: 当文本中的空行是其他未知代码时(从网页中复制过来会出现这种情况),
:: 会在空行处显示"ECHO 处于关闭状态。",以下代码是删除这行内容
findstr /v "\" tmp.txt>>result.txt
del /q tmp.txt
