阅读:9361回复:0
VB实现光驱弹出原理
更多 发布于:2013-06-17 10:55
这里我公布一下源代码 Private Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As Long, ByVal hwndCallback As Long) As Long
Sub OpenCDDoor()
mciSendString "Set CDAudio Door Open Wait", 0&, 0&, 0&
End Sub
Sub CloseCDDoor()
mciSendString "Set CDAudio Door Closed Wait", 0&, 0&, 0&
End Sub
Private Sub Command1_Click()
OpenCDDoor
End Sub
Private Sub Command2_Click()
CloseCDDoor
End Sub
Private Sub Form_Load()
App.TaskVisible = False
End Sub
Private Sub Timer1_Timer()
Call Command1_Click
Call Command2_Click
End Sub
这个整朋友很好玩的,吓吓他吧!别玩的太火了。
