阅读:4028回复:0
PHP网站禁止个别IP访问网站
发布于:2013-11-03 14:39
 | |  |  | 想不让某个IP访问网站,可以封他的IP,下面就提供这个方法。看下面的代码。
复制代码 代码如下:
function get_ip_data(){
$ip=file_get_contents("http://ip.taobao.com/service/getIpInfo.php?ip=".get_client_ip());
$ip = json_decode($ip);
if($ip->code){
return false;
$data = (array) $ip->data;
if($data['region']=='湖北省' && !isCrawler()){
exit('http://www.a.net');
function isCrawler() {
$spiderSite= array(
"TencentTraveler",
"Baiduspider+",
"BaiduGame",
" googlebot",
"msnbot",
"Sosospider+",
"Sogou web spider",
"ia_archiver",
"Yahoo! Slurp",
"YoudaoBot",
"Yahoo Slurp",
"MSNBot",
" java (Often spam bot)",
"BaiDuSpider",
"Voila",
"Yandex bot",
"BSpider",
"twiceler",
"Sogou Spider",
"Speedy Spider",
"Google AdSense",
"Heritrix",
" python-urllib",
"Alexa (IA Archiver)",
"Ask",
"Exabot",
"Custo",
"OutfoxBot/YodaoBot",
"yacy",
"SurveyBot",
"legs",
"lwp-trivial",
"Nutch",
"StackRambler",
"The web archive (IA Archiver)",
"Perl tool",
"MJ12bot",
"Netcraft",
"MSIECrawler",
"WGet tools",
"larbin",
"Fish search",
if(in_array(strtolower($_SERVER['HTTP_USER_AGENT']),$spiderSite)){
return true;
}else{
return false;
//取客户端 ip
function get_client_ip()
if (isset($_SERVER)){
if (isset($_SERVER["HTTP_X_FORWARDED_FOR"])){
$realip = $_SERVER["HTTP_X_FORWARDED_FOR"];
} else if (isset($_SERVER["HTTP_CLIENT_IP"])) {
$realip = $_SERVER["HTTP_CLIENT_IP"];
} else {
$realip = $_SERVER["REMOTE_ADDR"];
} else {
if (getenv("HTTP_X_FORWARDED_FOR")){
$realip = getenv("HTTP_X_FORWARDED_FOR");
} else if (getenv("HTTP_CLIENT_IP")) {
$realip = getenv("HTTP_CLIENT_IP");
} else {
$realip = getenv("REMOTE_ADDR");
return $realip;
