阅读:8527回复:0
C# 单ip端口扫描工具 (多线程)
更多 发布于:2014-04-03 10:33
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Net;
using System.Net.Sockets;
using System.Threading;
using System.Diagnostics;
namespace 端口扫描
public partial class Form1 : Form
ThreadStart threadstart;
Thread[] thread;
int port; //当前正在扫描的端口
int portmax; //扫描端口最大值
public Form1()
InitializeComponent();
public bool IsPortOpen(string ip, int port) //判断某一计算机端口是否处于打开状态
try
TcpClient client = new TcpClient(); //创建一个TcpClient实例
IPAddress address = IPAddress.Parse(ip); //转化string类型的ip地址到IpAddress
client.Connect(address, port); //连接服务器address的port端口
client.Close(); //连接成功立即断开
return true;
catch (Exception e)
return false;
delegate void Show_Change(string input);
public void ShowProc(string input)
this.lab_show.Text = input;
public void ScanThread()
while (true)
int nowport;
lock (this)
if (port > portmax)
return;
else
//lab_show.Text = port.ToString();
this.BeginInvoke(new Show_Change(ShowProc), new object[] { port.ToString() });
nowport = port;
port++;
if(IsPortOpen(txt_ip.Text,nowport))
listBox_Return.Items.Add(nowport.ToString() + "端口............开放");
private void btn_scan_Click(object sender, EventArgs e)
listBox_Return.Items.Clear();
int ThreadCount = (int)numericUpDown_ThreadCount.Value; //线程数量
thread = new Thread[ThreadCount];
threadstart = new ThreadStart(ScanThread);
for (int i = 0; i < ThreadCount; i++)
Thread t = new Thread(threadstart);
thread = t;
portmax = (int)numericUpDown_Max.Value;
port = (int)numericUpDown_Min.Value;
thread.Start();
private void Form1_Load(object sender, EventArgs e)
lab_show.Text = "";
private void Form1_FormClosed(object sender, FormClosedEventArgs e)
Application.Exit();
private void btn_ping_Click(object sender, EventArgs e) //ping按钮事件
string command = @"ping "+txt_UrlOrIp.Text;
txt_ping.Text = RunCmd(command);
public string RunCmd(string command) //运行cmd命令,并返回结果字符串
Process p = new Process();
p.StartInfo.FileName = "cmd.exe";
p.StartInfo.Arguments = "/c" + command;
p.StartInfo.UseShellExecute = false;
p.StartInfo.RedirectStandardError = true;
p.StartInfo.RedirectStandardOutput = true;
p.StartInfo.RedirectStandardInput = true;
p.StartInfo.CreateNoWindow = true;
p.Start();
return p.StandardOutput.ReadToEnd();
int[] port_array = { 21, 23, 80, 1433, 3306, 3389 }; //常用端口
string ip;
public void Scan()
for (int i = 0; i < port_array.Length; i++)
if (IsPortOpen(ip, port_array))
listBox1.Items.Add(port_array.ToString() + "端口.............开放");
listBox1.Items.Add("");
else
listBox1.Items.Add(port_array.ToString() + "端口.............关闭");
private void btn_Start_Click(object sender, EventArgs e) //扫描计算机常用端口
listBox1.Items.Clear();
ip = txt_IpAlways.Text;
ThreadStart ts = new ThreadStart(Scan);
Thread th = new Thread(ts);
th.Start();
